Is it possible to convert a 3/4" Wagon Wheel to 1"?
Old Sep 23, 2024 | 03:27 PM
07UltraGuy's Avatar
07UltraGuy
Great info. Many thanks.
My plan is to re-use the inner sleeve & match the factory dimensions from my black rear wheel.
Getting this wheel machined for the 1" axle sleeve should be far less expensive than buying another wheel.
Old Sep 25, 2024 | 09:24 AM
bustert's Avatar
bustert
like i said possible but advantageous?
if the rim mfg says it is OK, no issue, BUT
remember, this is a cast wheel, NOT BILLET!!!
that said, there could be out gassing pockets that are opened up. safety is the issue, not that it can be done.
just because you stick your finger in a light bulb socket without recourse, does not mean that one day someone actually turn the power on.
the thing about cast is it can fisher. around here, rim shops will not touch a mc wheel.
Old Sep 25, 2024 | 10:13 AM
eighteight's Avatar
eighteight
FWIW: H-D never changed the p/n on early to late wagon wheels
If the vendor factory had no issue drilling this casting to 2 different diameters, then neither do I
JMO
loseranacummins
Wheels/Tires
16
Mar 25, 2025 12:03 PM
Rob Harper
Wheels/Tires
Sep 26, 2023 10:49 AM
RK_RIPPER
EVO
May 20, 2022 03:31 PM
HD-Heaven
Aug 22, 2018 07:56 AM
taterbum
Wheels/Tires
Sep 12, 2015 11:19 AM
