Change a valve stem without removing the wheel?
Old Dec 31, 2024 | 02:20 PM
elPrez's Avatar
elPrez
Default Change a valve stem without removing the wheel?
I've seen videos of sport bikes and smaller bikes but how about an Ultra Limited. Can the bead be broken with a clamp and the tire squeezed enough to access the valve stem or it that just asking for trouble.
Old Dec 31, 2024 | 04:07 PM
touchdown's Avatar
touchdown
Don't see why not.
Old Dec 31, 2024 | 04:23 PM
bustert's Avatar
bustert
go for it. just break the bead on the stem side.
Old Dec 31, 2024 | 05:21 PM
elPrez's Avatar
elPrez
it’s in the middle
Old Dec 31, 2024 | 05:24 PM
Uncle Larry's Avatar
Uncle Larry
I see this going south ... Drop either the old or the new valve inside the tire and it may be (very ) difficult to get it out ... One of these may make it a bit easier ??
https://www.google.com/search?q=tire...t=gws-wiz-serp
Old Jan 1, 2025 | 06:32 AM
deperdue's Avatar
deperdue
Not real sure about your bike but it was very easy to do on a 2018 lowrider, just be careful so it doesn't fall into the tire. If it does I think a pickup tool would get it.
Old Jan 1, 2025 | 08:16 AM
bustert's Avatar
bustert
a cheap piece of clear plastic tubing will do the same. push on old, fish out, attach to new and thread in.
reason i said one bead is because some times it is difficult to reseat both beads especially on the machine.
Old Jan 1, 2025 | 09:14 AM
mskirwin's Avatar
mskirwin
Go for it, it should work.
Old Jan 1, 2025 | 09:22 AM
Rounders's Avatar
Rounders
I see this going south ... Drop either the old or the new valve inside the tire and it may be (very ) difficult to get it out ...p
If it did, couldn't you just pop the tire like normal? So really not a big deal.
For putting in you could run a line through it with a nut, so you couldn't lose it. Couldn't do the same from outside in, if you lose it, easier find the string or tywrap.
I never thought you would be able to get your hand in there.
Old Jan 1, 2025 | 11:31 AM
Paintslinger16's Avatar
Paintslinger16
Active Streak: 120 Days
Sounds like way more work than just pulling the wheel
