Need some advice
Old May 19, 2025 | 12:23 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by Coal-Train
My front tire size on my 2011 ultra limited is 130/80hb-17.
what does the hb mean on the size? Can I run a 130/80-17 that doesn’t have the hb on it? Sorry if this has been asked before I tried searching the forums but couldn’t find the answere.
I bypassd the "hb"and left you the following "advice" because it's the only information you really need and I've never seen a tire with the "hb" in the Size Code ... "B" yes, but "hb" No.
Pick any 130/80B17 that you would like (don't worry about the "HB")
Did you physically see "hb" on your tire or did you just get the spec online? When I googled "130/80hb-17" the only thing that was relevant was a Dennis Kirk spec sheet below
I asked Dunlop about the "HB" and here was their reply ...
Thank you for contacting Dunlop Motorcycle Tires. I cannot answer your questions about what the H stands for as I don’t believe we offer a tire with those indication markings. We would offer a 130/80B17 65H, the 65 (639 lbs) being the load capacity and the H (130mph) being the speed rating.
If you can provide a pic of a "130/80hb-17" or "130/80HB17" on the tire, I would like to see it
Old May 19, 2025 | 12:25 PM
multihdrdr's Avatar
multihdrdr
@Coal-Train see post above ... Forgot to "Tag" in the above post and I don't believe it sends a PM msg if you add the "Tag" in a "Edit"
propflux01
The Dark Side
Aug 1, 2018 05:37 AM
Blackops48
Oct 10, 2016 01:56 PM
Joe Dirt 14
The Dark Side
14
Mar 4, 2016 06:09 AM
Ohiobellboy
Apr 16, 2010 09:21 AM
