front brake caliper clicking
Old May 29, 2009 | 07:13 PM
0lowrider1's Avatar
0lowrider1
Default front brake caliper clicking
got a 94 fatboy...the front brake has a clicking sound when rolling...apply the brake and it goes away till you let off...the caliper bottom bolt seems to have a little play in it...i can move it and hear it click..the bolt is tight..just started doing this...any ideas..a bushing worn ?
Old May 29, 2009 | 07:38 PM
robzuc97's Avatar
robzuc97
Default That's a rare '94!
At first I thought you had a newer bike with ABS [clicking would be normal]; you have a rare '94 Fatboy with ABS! LOL Clicking is not good for regular disc brakes... Can't say for sure what would be wrong but definitely warrants investigation esp. if you can move the bolts by hand; the calipher will "wiggle" a little around by hand and is normal. There are three o-rings in there which could go bad [p/n 44059-83] I suppose and cause too much wiggle. There are guide pin kits available [p/n 44053-92A] which include the rubber boot, guide and three mounting pins that may correct also.
rquest
Dec 4, 2020 11:43 PM
Samurai71
2014-2024 Touring Models
Jun 8, 2018 07:33 PM
SSteve
Jan 14, 2017 02:25 PM
Woodys03
Wheels/Tires
Sep 4, 2015 02:10 AM
Ben A
Wheels/Tires
Mar 24, 2011 11:37 AM
