mushy front brakes
Old Jun 8, 2009 | 08:24 PM
RE AND CHERYL's Avatar
RE AND CHERYL
Default mushy front brakes
The front brakes on my 01 Ultra are and have been mushy since I've had the bike. I've bleed them several times and gotten no air out of the system and had no improvement in braking. In short...The brakes suck.
Re'
Old Jun 9, 2009 | 03:46 PM
stroker1948's Avatar
stroker1948
This will fix them... I guarantee it. Take off one caliper at a time, double over a piece of cardboard from a box and slide it between the pads on the caliper that is off. Now pump the heck out of the brake lever until it pumps up tight. Purchase a can of spray brake cleaner from an auto parts store.. Now spray the caliper pistons down real well cleaning off all brake dust and grime.. Now pull out the cardboard and either using a large screwdriver or puddy knife between the pads spread them until the pistons you just cleaned are fully retracted into the bore. Re-install it and torque the bolts 28 - 38 ft lbs. Now do the other side exactly the same way. After both are installed pump up the brake, you are going to be amazed at the differance. Use Dot 5 fluid in that 2001 bike. You don't need the Dot 4.
Let me know how this turns out. I fix a lot of them with this method and my customers can't beleive it.
Stroker
Old Jun 9, 2009 | 04:51 PM
ajayrk's Avatar
ajayrk
Stroker
Old Jun 9, 2009 | 06:58 PM
RE AND CHERYL
Sounds a little crazy, but you appear to talk from experience. I'll try it and get back to ya.
Re'
Old Jun 9, 2009 | 08:06 PM
Harleypingman's Avatar
Harleypingman
The procedure described above is intended to clean the caliper pistons. They accumulate brake dust over time which causes them to stick in their bores requiring more and more lever pressure to make them move--that's the mushy sensation and excessive brake lever travel you are experiencing. You can also find essentially the same cleaning procedure at this link from Lyndal Racing Brakes' website:
http://www.lyndallracingbrakes.com/service_tech.htm
I've used the procedure myself after a tech at my local HD store told me about it--the change in lever feel and travel was "miraculous" IMO.
Good luck with your project.
Old Jun 10, 2009 | 02:28 PM
stroker1948
Been working on bikes 42 years now. Little tricks like that come from experience.
Stroker
Old Jun 10, 2009 | 02:33 PM
azharleyrider86401's Avatar
azharleyrider86401
Did the exact repair recommended and it fixed mine. Rode for a year with a crap lever now have to worry about grabbing too much. As I extended the pistons out only two wanted to move so I had to mess with it quite a bit but after cleaning and forcing all the way bike they are awesome. By the way my first guess was the master and re-building that didn't do s$%t. I have!!!
Old Jun 10, 2009 | 08:38 PM
UCRED's Avatar
UCRED
Smile
Not only is the proceedure on the Lyndall Racing Brakes great. You should consider changing the pads to their Z+ or Golds. Since I switched to Paul's product I will never use anything else! The customer service is outstanding.
Old Jun 19, 2009 | 07:48 PM
jungleman's Avatar
jungleman
Done this om my 2002 EG yesterday works like a charm. Great advice.
Old Jun 20, 2009 | 06:05 PM
stroker1948
Glad to help. I have been working on bikes for 42 years and I still learn things from this forum and various tech writings.
Stroker
