Heres a simple and FINAL fix to the "brake pad squeal"
You will need an air powered die grinder with an abrasive cut off wheel to sucessfully groove the brake pad material.
No guarantee's that this will work for everyone, but it worked perfect for me! Softail rear brake pads are super easy to remove. Just retract the pads back just a bit with a screwdriver, remove the two 1/4" 12pt brake pad pins, and the pads will drop right out.
Now my rear brakes are perfectly quiet, NO squeal, NO vibration, NO loud chatter... NOTHING. Heck I even think I feel slightly better rear braking force....
Ron
