disabling abs to allow for single front rotor?
Old May 8, 2010 | 11:37 AM
hendog717's Avatar
hendog717
Stage II
Default disabling abs to allow for single front rotor?
I have a 08' road king classic with abs and want to go to a single front left rotor to show off a larger rim. is there any WRIGHT way to do this without causing saftey concerns or is it not possible to do unless u disable the whole abs system?
Old May 8, 2010 | 11:42 AM
lionsm13's Avatar
lionsm13
Wright way? You had better talk to your dealer, or you will probably void your warranty, I would think?
Old May 23, 2010 | 09:17 AM
havenolife's Avatar
havenolife
If you pull the abs fuse it will resourt back to regular brakes but will show a flashing abs light to let you know thay are not working
Old May 31, 2010 | 05:52 PM
db45's Avatar
db45
you are considering getting rid of an extremely safety related feature, to show off a rim?????? have you ever HAD to use your abs. By that I mean locking up the brakes at 55 mph? if you end up needing to do that before you get rid of them, i guarantee you'll keep the abs.
just my opinion
Old May 31, 2010 | 08:39 PM
Michael M's Avatar
Michael M
5th Gear
I've had to use the abs twice in the last year. Still here to type a response.
No way would I disable it to show off a rim. To each his own I guess.
Old Jun 1, 2010 | 06:35 PM
db45's Avatar
db45
I've only had to use it once, but I am quit certain if the abs wasnt there i would have ended up in someones back seat.
Old Nov 24, 2010 | 07:39 PM
hendog717's Avatar
hendog717
Stage II
didnt want to sacrifice saftey...but thought i could oversize the front left brake and still keep the abs...? i have engaged the abs b4 and it was nice..but what about all the previous bikes that never had abs b4? seemed to work for them. im not biased ever way...just wanted to c if it could b done.
Old Nov 24, 2010 | 08:25 PM
peppi's Avatar
peppi
If I had the ABS system, there's no way I would disable the system just to show off the wheel JMHO.
Old Nov 28, 2010 | 12:10 PM
rkadair's Avatar
rkadair
I would never have ABS well maybe the rear only
Old Nov 28, 2010 | 04:37 PM
mkguitar's Avatar
mkguitar
It's your bike, do what you want.
It's a bad idea.
My license plate is 37M8. Please don't ever ride behind me.
I've been rear ended before by riders who didn't know how to ride/stop etc.
MK
