dyna beads..where to get
https://www.hdforums.com/forum/wheel...d-install.html
Regards,
1. No need to rebalance. The tire is always balanced, unlike conventional weights that need rebalancing as the tire wears out.
2. The ride is really smooth, better than conventional weights, IMHO, because the balancing weight of the ceramic beads is all the way out, just inside the thread surface, where they can exert the most leverage.
3. Install and forget. no need to change anything.
4. They work equally well in tubeless tires or innertubes.
CON's
1. If you have a flat and you use slime to repair it, you will really have a tire out of balance, with dynabeads in clumps.
2. If you have flat, you have to put a patch inside the tire (on tubeless) so the beads will have a smooth surface to roll in. This is not a problem with innertubes, of course, because you put in a new tube anyway.
3. You have to decide what to do once you have a flat. Are you going to carry a couple of ounces of 'beads when you take a trip just in case, or try to get your old 'beads out of the old tire or innertube.
In my case, a have a small ziploc bag with 'beads that I pack with some tools when I go on a trip.
Regards,
