I have a set of them in one of my wheels and haven't had any problem with them. They have been in for about 3 years and have around 40,000 miles on them.
Needed the 9285 double bearing with the extended race for the IDS pulley cause its the one that went bad.
Since the 9285 bearing was dealer item only the dude at the Indy shop ordered all the bearings from Harley
You can buy almost any bearing from a Bearing business. They sell to industry mostly but can get any bearing made you want.
The bearings have numbers on the side that give, in Millimeters, all the info needed.
And you then can get any brand you want.
Check and see.
I have a 2008 Fatboy and had to replace the rear wheel bearings on it with only 7K on the bike ended up just using moco parts but I do think I will be looking into something aftermarket next time. I was getting wheel wobble as wheel as a circular grinding noise while riding
