Wheel bearing
Old Dec 11, 2010 | 08:49 AM
Old Gunny's Avatar
Old Gunny
Remember torque is all relative. The temp you are working at can change things with aluminum wheels. And the driven part is the outside race but the working part is the inner race. Have to work with these requirments.
I just took it down a little at a time when it got even with the wheel side and felt the spacer. When there was no spacer wiggle and in fact the spacer would turn the other bearing but easy turning,---That was it.
Once you drive the bearing in too far you can't really pull it back without damage even if you can't see the damage.
When the Axle is tightened the inner races are tighten harder and the slight movement is there.
I know it all sounds all **** but there is really no other way. The values you are looking for are all in your fingers really.
Its worth your life or, at least sometime, a big hit to the wallet.
Old Dec 11, 2010 | 04:48 PM
0734's Avatar
0734
Isn't it just normal for our beloved MOCO to have a specified tolerance of "just touching". Just touching could mean just about anything among individuals making the judgment.
Old Dec 13, 2010 | 07:47 AM
Old Gunny's Avatar
Old Gunny
Its a bearing thing.
They are all like this. One way or another.
The whole point to all this, is to think about what what you are really doing. Trying to read a torque wrench? Or set bearings.
Engineers have to deal with tolarances ranges and somewhere there is a list of exactly the base conditions. Temp,etc. But there is a real world we all live in so you have to think about what is going on and why we do what we do.
Old Dec 13, 2010 | 07:56 AM
0734's Avatar
0734
My trucks, cars, tractors, lawn mowers and trailers rarely ever seem to have bearing issues.The MOCO seems to always have bearing issues...as in both inner and outer cam bearings and now wheel bearings.
Does anybody know why they left the torrington/timken style and went with the current bearing system? Was it to reduce bearing service intervals, or a cost thing? Like.....it takes less than 30-minutes to re-pack a set of tapered bearings.
Old Dec 28, 2010 | 06:50 AM
masterblaster's Avatar
masterblaster
Interesting I wonder if my dealer is doing the install correct? I am on my 3rd set on the fronts. Thanks for teh info gents.
Old Dec 28, 2010 | 12:53 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Originally Posted by Old Gunny
Also found why some may fail.
Ones I took out of my front wheel were very hard to turn, why I started to worry.
When I took them out they were really OK. Had grease and, once I got the first little pull on one, they both turned fine.
With HD instructions you put the Primary, left side, bearing in first and bottom it out on the inner ledge. Then the spacer goes in.
The spacer, by the way is very stout, and nobody is going to crush it, period.
Then install the other bearing till the inner race touches the spacer.
KEY WORDS. --TOUCHES
Now the rub.
If you go past that point by continuning to drive (force ) the bearing down past that point you force the INNER races HARD against the OUTER races. You are driving the outer race and at the same time the spacer is against the inner race ----***** are tight in the bearings.
This is a very tiny movement
There is nothing to stop you from doing this, no lip- ledge- here.
Same as leaving a tappered bearing tight, everybody knows that is a no-no.
Got to take a little time at this last point and double,tripple, check the last few bits of movement and get the bearing set but still leave clearance to move.
These bearings are deep grove, single row, and designed to take some side load, and they need to be able to move in their groves as designed.
Or the bearing will have a much shorter life.
Mine from the Factory were set too tight. This is very easy to do if you don't take care.
If you have the right tools made than there is no way of getting the races shifted to the inside. A set of tools should have the the axle metal part (inner race) parallel with the outer race. Locate (press) the outer race part of the bearing onto the hub shoulder than insert the axle wheel bearing spacer than the other side of the hub insert the bearing until it is tight against the axle wheel bearing spacer. The outside should match the appropriate OD measurement (different on different models ie: Wide Glide, Mid Glide et Al.). The axle wheel bearing spacer should be 0.006" longer to allow the bearings to ride in the center of the races on both sides (0.003" +0.003"). The bearings should press in smoothly and parallel to the hub socket & not cocked. This last part of the sentence is when you are making the axle wheel bearing spacer as well as the outer axle spacers.
There is a big difference in bearings. They may look the same but it is the tolerances they are made for. That includes the exact diameter of the ball as well as the roundness. There are two bearing makers in China that produce excellent industrial bearings. Look at the specifications before you buy. Just because it says made in the USA does not mean they are the right bearings for you.
Old Dec 30, 2010 | 10:21 AM
Old Gunny's Avatar
Old Gunny
I'm sure the Chinise can make good bearings, why not?
But even HD bearings don't say one thing on them but part number and branded with a HD sign, on the rubber seal.
Who makes them? Who knows?
And today bearings are a big counterfited business.
If I buy a little old bearing that cost 15 dollors and my life might depent on, from a Industrial supply business down the street, that is identified correctly from a name brand.
Or
Buy a pak of, "8 for 18 bucks", that say the same each from a online source.
Old Jan 13, 2011 | 10:26 AM
gmurdock's Avatar
gmurdock
My front bearing wore out at 21500 miles. They had replaced it around 6000 miles when they messed up putting on a 408 tire on it. Had it in for 20K check up they said everything was good. At 21500 I had a bad vibration especially in curves. Took it in they test road it said neck bearing? When they looked at it in the shop said it needed retorqueing? Then they called me back to show me the front bearings where bad. Front tire you could move almost 2"s from side to side? They replaced them under warrenty. When I asked about them going that bad in 1500 miles they said it could happen? They did not like me asking how they could go that bad in that short of miles sence the check up. I know 1 guy on here says he replaces his every time he changes tires. I think I am going to start doing that. Will most bearing places know what I am talking about for ABS bearings? Sorry for the long post.
Old Jan 13, 2011 | 07:59 PM
dawg's Avatar
dawg
Originally Posted by gmurdock
my front bearing wore out at 21500 miles. They had replaced it around 6000 miles when they messed up putting on a 408 tire on it. Had it in for 20k check up they said everything was good. At 21500 i had a bad vibration especially in curves. Took it in they test road it said neck bearing? When they looked at it in the shop said it needed retorqueing? Then they called me back to show me the front bearings where bad. Front tire you could move almost 2"s from side to side? They replaced them under warrenty. When i asked about them going that bad in 1500 miles they said it could happen? They did not like me asking how they could go that bad in that short of miles sence the check up. I know 1 guy on here says he replaces his every time he changes tires. I think i am going to start doing that. Will most bearing places know what i am talking about for abs bearings? Sorry for the long post.
9276a (2)
9252 (2)
Old Jan 14, 2011 | 07:02 AM
gmurdock's Avatar
gmurdock
Thanks Dawg
01fxst
Jun 17, 2011 07:58 AM
Mr.Softy
Sep 29, 2010 10:36 AM
gearedforacure
Jan 23, 2010 09:06 AM
bikehunter
Sep 15, 2009 06:04 AM
rider
Sep 30, 2007 05:26 PM
