DOT4 v DOT3?
Old Jan 27, 2011 | 01:36 AM
Jeff W's Avatar
Jeff W
Default DOT4 v DOT3?
Is there any particular reason why I shouldn't use dot3 and opt for dot4 other than a slightly higher boiling point?
Old Jan 28, 2011 | 09:27 AM
slothy's Avatar
slothy
DOT 4 Is a little better also for not collecting as much moisture
Old Jan 30, 2011 | 08:59 AM
xwhyz1959's Avatar
xwhyz1959
DOT 4 is paint friendly as well is it not?
Old Jan 30, 2011 | 12:18 PM
Jeff W's Avatar
Jeff W
I just went and picked up a bottle of DOT4. Thanks for the answers.
Old Feb 2, 2011 | 05:06 AM
05Hog's Avatar
05Hog
Keep 3 and 4 away from paint. DOT 5 is synthetic....it's ok
Old Feb 2, 2011 | 11:44 AM
Manes's Avatar
Manes
Default Wait!
You might not want to mix different types of brake fluid without first checking to make sure there compatible. I'm not sure about DOT 3 + 4 but I know your not supposed to mix DOT 5 with anything else. Bad thing happen, so I've been told.
Old Feb 2, 2011 | 11:50 AM
slothy's Avatar
slothy
mixing dot 3/4 are fine... stay away from adding 5... you can add 5.1 but will dilute the higher boiling point.
giacomo56
Feb 27, 2017 08:27 AM
Mr.Softy
Sep 21, 2013 03:17 PM
duoglider
Oil Archive (no new posts)
11
Jul 30, 2009 06:42 PM
SH_01FXDWG
May 18, 2009 11:52 AM
outfishin35
Mar 29, 2007 05:12 PM
