Late model wheels on an '06 Bagger
Old Feb 1, 2011 | 08:59 AM
14/88trucker's Avatar
14/88trucker
Default Late model wheels on an '06 Bagger
So I have hunted the forum and googled everything imaginable. I need a good answer to my question. What needs to be done on a 2007 or later 25mm bearing front wheel to be run on a 2006 or older 1" bearing bike. Can I just buy a 25mm axle and swap my rotors over, or do I need to purchase a new bearing conversion kit of some sorts? Any help would be greatly appreciated. I am wanting to put a 2010 FLHX 18" front wheel on my 2006 FLTHCI.
Old Feb 8, 2011 | 07:35 PM
97badfatboy's Avatar
97badfatboy
I would think the forks on your 06 are made for the 1" axle. As i would believe the forks on a 07 and up are made for the 25mm axle.
Old Feb 9, 2011 | 04:48 AM
grbrown's Avatar
grbrown
Later wheels will accept bearing kits for 3/4", 1" as well as 25mm bearings. You need a bearing kit which you should be able to get from your local friendly dealer, or on-line discount dealer. You may need different axle spacers as well.
Not many members look in on this part of the forum, so you would be better visiting the Touring part. You'll find earlier posts on this and get more help in there!
Old Feb 16, 2011 | 12:32 PM
14/88trucker
Thank you for all the help!
Old Jun 8, 2011 | 09:08 AM
hd-kw's Avatar
hd-kw
Glad I finally found this. Wanting to do the same thing .
Old Jun 30, 2011 | 08:10 PM
Spankys04UC's Avatar
Spankys04UC
Stage IV
talked with parts guy at a dealer in DC he put 2010 street glide wheels with 25mm bearings told me to get axle and spacers and bolt it in. I want the 18 street glide wheels myself. My question is can i put the rear wheel tire and al with the wider tire?
Old Jul 1, 2011 | 02:30 AM
grbrown's Avatar
grbrown
I assume you have an 04 Ultra! I don't think it is an easy conversion, for several reasons, although it may be possible. I recommend you take a look in the Touring forum, where there are a few threads about this. I have installed an 07 swingarm and 04 rear wheel in my old Evo, along with a 150 tyre. There may be room for a 160 tyre, but going wider will IMHO require a bit of magic!
Joey Pennington
Sep 24, 2019 02:52 PM
ThaGlyde
Jul 22, 2016 10:27 PM
Bspike1
Jun 29, 2012 05:46 PM
joechief
Oct 7, 2011 03:12 PM
bdbaggr
Nov 10, 2010 05:13 PM
