Front Brake Problem. Need Help!
Old Sep 5, 2011 | 01:29 PM
16VAFXDL's Avatar
16VAFXDL
Default Front Brake Problem. Need Help!
I just had my local indy shop change the brake pads for me last week while it was in the shop for a new front tire. He installed a set of HD brake pads on my bike (my choice). When I picked it up it had virtually no brake pressure and no real front stopping power. I could also pull the lever all the way to the grip. I bled the line and there is no air in the line. I also took the caliper off, removed the pads and reinstalled them. I can still pull the lever to the grip and there is no air in the line. It looks like the pistons are moving in and out but not far enough to contact the back of the pads. Is it possible that the pad clip spring in the pistons could be bent and prevent the caliper from working or does anyone have any other idea what it might be? I am trying to determine if the caliper might be bad.
Old Sep 7, 2011 | 07:56 AM
grbrown's Avatar
grbrown
There is a thread called Soft Front Break Pull above this one, with hints and tips on this. You are not alone suffering from it. Also look at the DIY forum for even more help.
Old Sep 9, 2011 | 03:51 PM
16VAFXDL's Avatar
16VAFXDL
Came to the conclusion, after doing some more searching here on the forums and then with a little troubleshooting, that the actual problem was the master cylinder because it was bleeding down when we tried to pump up pressure. Used the master cylinder rebuild kit to replace the piston and parts and that solved the problem.
Old Sep 9, 2011 | 03:55 PM
parabellum_9x19's Avatar
parabellum_9x19
Yeah, I was going to suggest that its possible the seals were gone in your m/c.
Its supposed to pump fluid to the pads, and then when you release, let the pressure off without letting much flow back into the master cylinder....but if the seals go, it will let the pads walk right back when you let off on the handle.
How often did you change your fluid?
Cullmanco
Dec 17, 2018 06:16 AM
that$pit
Feb 9, 2015 01:19 PM
Chicago 03 King
May 17, 2011 09:15 AM
beaureed445
Jul 1, 2008 03:40 PM
kevdog
Aug 23, 2006 03:21 AM
