Soft front brakes- Need help
Old Jul 22, 2012 | 12:39 AM
babalusfd's Avatar
babalusfd
Stage II
Default Soft front brakes- Need help
I recently bought 2004 Road King and the brakes are really soft. I need to pull the lever in about halfway before I get any braking. I thought it might be air in the lines so I have bled both lines down at the wheel and I have even tried to bleed up on the master cylinder with no luck. If anyone can help with any recommendations- I would really appreciate it.
Thanks
Old Jul 22, 2012 | 04:18 PM
babalusfd's Avatar
babalusfd
Stage II
I got it fixed- I followed the tips in the brake fluid poll for cleaning my caliper pistons and it worked.
Old Sep 16, 2012 | 12:07 AM
rasa777's Avatar
rasa777
I had the caliper pistons cleaned and it worked for 500 miles and went back to soft. Had the lines bled and it did nothing. My indy shop says I need a new master cylinder but even if I change it out it will probably only engage after halfway mark.....doesn't sound normal to me....especially since I've been riding sport bikes most of my life....
2004 road king bought recently with 1,500 miles....I now have 5k miles on it
Old Oct 12, 2012 | 08:31 PM
rasa777's Avatar
rasa777
had the master cylinder replaced.....did nothing! Now I'm going to have the calipers rebuilt.....I'm guessing it will do.......NOTHING!
Old Oct 15, 2012 | 10:32 AM
grbrown's Avatar
grbrown
There is a thread in the DIY section on bleeding brakes.
Old Oct 22, 2012 | 11:33 PM
rasa777's Avatar
rasa777
just had the calipers rebuild.....feels the most solid I've ever felt it.....I'll let you guys know if it last......
Old Nov 15, 2012 | 03:15 PM
rasa777's Avatar
rasa777
it's been 500 miles since having the calipers rebuilt. It solved the problem!!! The brake works amazingly well....I've never had it feel this solid.....
Old Nov 24, 2012 | 11:25 AM
HD HERB's Avatar
HD HERB
guess im going to have to rebuild my front ones there the same way and i ve done eveything else even changed the lines so i guess i l try the calipers now and see if that helps
Nokkon Wud
Wheels/Tires
11
Jul 1, 2015 11:30 AM
mattflow
Feb 2, 2015 03:57 PM
2003sportster
Oct 29, 2014 08:05 AM
dcoffing
May 15, 2013 09:47 PM
golfmajic
Aug 17, 2011 04:01 PM
