Brembo pad noise
Old Nov 28, 2012 | 06:15 PM
Bub_95's Avatar
Bub_95
Stage III
Default Brembo pad noise
I have a pad that won't stay in spring and hits pin when applying brakes. Is this common and is spring normally in stock? Thanks
Old Nov 29, 2012 | 10:34 AM
Chief Davis57's Avatar
Chief Davis57
Is this the front? And are the pads OEM or aftermarket? Unfortunately you don't have (probably) another caliper to compare like on a car. That way you can see if there is anything different about the malfuncioning caliper/pad. When you say pin are you referring to the caliper pin? Sorry for all the questions. If a new spring is not available perhaps comparing it to a new one from a new assembly will show whether the spring is the problem...
Old Nov 29, 2012 | 06:03 PM
Bub_95's Avatar
Bub_95
Stage III
everything oem with 12k, looked at other side spring clip looks to be slightly bent. I think the pad is droping out of the clip, I can take screwdriver and push pad back up and roll wheel and it drops back down. Looks like I need to get a new clip. Thanks for responding Bub
CBCanada
May 30, 2016 10:46 PM
Medicinman369
Wheels/Tires
Jan 4, 2013 04:08 PM
Figstr
Oct 4, 2010 01:32 PM
Aaron01
May 27, 2009 11:37 AM
bucs012
May 13, 2008 01:38 PM
