I've got an '06 Heritage with 52,000 miles. Starting to get some noise on the highway from the front wheel area. I'm thinking maybe a wheel bearing going bad. Is this a do-it-yourself replacement, or should I just bite the bullet and take it to the shop?
The removal and replacement of these on e piece bearings require some special tools that run approx $700 (in Canada). Trying to knock them out with punches etc will destroy the wheel IMHO. Dealer will have the proper tools, any independant that has the tools. fwiw Fastrider124
I bought a wheel bearing puller and gave up with it! I couldn't make them budge. My nearby Yamaha dealer had the tools to pull the old bearings and fit my new ones.
If you get the removal and install tols from HD you can do it yourself. Never use a hammer on removing or installing. Check out the you tube videos and ballance the cost of the tools with the price the dealer quotes you.
Look at #740010. You need the service manual as there is a specific procedure to install the bearings and the wheel/axle to insure proper caliper/rotor alignment. Don't know what the dealer charges but check it out. Bearings are about $12/each. Probably a four hour job for a first timer on the front if you have the parts and tools on hand and Murphy doesn't intervene.
Good punch and a heavy hammer works for me. First time you pull the inner sleeve out its a good idea to notch it for future removals.
If you have a press to install the bearings, that will work, providing that the spacer will move enough to let you get a drift punch to make full contact with the inner race. Even so, it's a struggle. I have a press so when one has been removed, I can press the other out. I have done it that way once and that's when I bought the tool.
You can't, or I should say, shouldn't ever drive the bearings back in; bad juju.
I know. You just gotta hit them on the outer race or find a piece of pipe lying around to do it. I got a 6' arbor press at work I drive them back in with. Sure if I had the $$$ for special tools id get it but for me its over kill. I did say fir me. Everyone else should get the right tool.
Same old story with me. Down and dirty and get by with what you got.
