fork reflector removal disastor
Old Jul 28, 2013 | 08:40 PM
Iceman24's Avatar
Iceman24
Pic's a tad fuzzy, but it sure looks like leftover double-stick tape from the reflector...get some "Goo-Gone" and try to remove...
Old Jul 28, 2013 | 08:44 PM
mmcbeat's Avatar
mmcbeat
I pull my reflectors off and have never had any problems. You might consider putting them back on to hide the mark. Cheap fix.
Old Jul 28, 2013 | 08:57 PM
Harleycruiser's Avatar
Harleycruiser
Originally Posted by MacKo2000
Great I'll look for some tomorrow. Thanks for the help. And if it doesn't work I look into powder coating it.
Well before you spray clean off any wax from the metal polish with lacquor thinner or gas, that will help the clear stick, and if it is left over glue it will come off.
Use just a small amount on a rag wrapped over your finger, just on the bare spot.
Old Jul 28, 2013 | 09:09 PM
im's Avatar
im
Put reflector back on with 3m double sided tape or some other emblem tape.
Not worth the trouble to do anything else at this time.
Old Jul 28, 2013 | 09:28 PM
klaybus's Avatar
klaybus
http://www.kuryakyn.com/documents/in...-22HD-0408.pdf
Old Jul 29, 2013 | 07:01 PM
MacKo2000's Avatar
MacKo2000
Came across clear coat touch up pen. Does anyone have any experience with these. I think I would be more able to treat the exact location needed to be corrected with a pen vs spraying it?
Old Jul 31, 2013 | 11:25 AM
sailingwj's Avatar
sailingwj
I have them on my 07 Deluxe and even moved them out on the rear set as the custom bags covered them up....I don't LIKE the look at all as I've worked hard and spent lots of $$$$ to get it looking as much like a DuoGlide as I can...so why did I move them...DOT requires them, and if someone ever hits you...a sharp insurance company lawyer will twist it to show you non-compliant and contributed to the accident....
Old Jul 31, 2013 | 11:31 AM
sailingwj's Avatar
sailingwj
I have used the pen in other applications...its not glassy smooth but if you put a couple coats on then use 1000 grit wet sand...very carefully...and then polish with a very fine polish...mothers makes a couple pastes and the cleaner wax is extremely fine, although I usually have to work up to that with the paste...take you time and tape the area so the surrounding finish isn't effected...remove the tape just before you have the desired gloss and feather to the area with the polish...nothing to loose...
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Get some take off forks and a service manual.
Old Aug 5, 2013 | 07:49 PM
Rusty Gunn's Avatar
Rusty Gunn
Hey, that was a nifty idea you had there. What the heck, a guy don't need no stink'n reflectors on his forks. After all it's a well known fact that car drivers have NO difficulty at all seeing motorcycles, especially at night.
pureoper
Apr 14, 2009 09:08 PM
cherrypewt
Dec 30, 2007 04:00 PM
relli
Jun 6, 2007 06:31 AM
vheflin
Mar 25, 2006 03:52 AM
05Fatty
Feb 14, 2006 08:07 PM
