Wimmer Compression Releases
Old Jan 29, 2013 | 05:15 PM
MikeTD3's Avatar
MikeTD3
Default Wimmer Compression Releases
I got no response from the Engine forum so I figured I would try here.
Any feedback out there on these? I was thinking this would be a quick way to assist with hot start issues using the SE255 cams; perhaps using one in the rear cylinder.
http://bikerpics.org/product-categor...press-release/
I would rather not pull the heads until I am ready for a 107" upgrade, then I will have the heads ported, add MCR or ACRs, change cams etc.
Old Jan 29, 2013 | 05:57 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Looks interesting and easy to install, wonder what the negatives, if any, are........I would have to get rid of my super spark plugs that I paid $30 for, that's one draw back.....
Old Jan 29, 2013 | 06:02 PM
soft 02's Avatar
soft 02
Looks like a half *** solution.
Old Jan 29, 2013 | 06:07 PM
MikeTD3's Avatar
MikeTD3
Why? It just needs to release compression.
Old Jan 29, 2013 | 06:09 PM
soft 02's Avatar
soft 02
First it moves the spark plug back and second durability I would question.
Old Jan 29, 2013 | 06:17 PM
icebite1's Avatar
icebite1
And the SE releases are only $85 a pair in the SE catalog.
If you are thinking of a FuelMoto 107" , they put manual releases in for $100 a pair including the releases.
The ez-release you asked about seem kinda expensive for temporary.
I know you want something now so just throwin it out there.
Old Jan 29, 2013 | 06:37 PM
MikeTD3's Avatar
MikeTD3
Yeah I wonder about that as well...I may call them.
I hear ya....but I just hate the thought of pulling the heads for just the releases and it just isn't in the budget to do what I want this year......decisions, decisions.
Old Jan 29, 2013 | 07:08 PM
79289Chase's Avatar
79289Chase
I need releases in a bad way to but I don't really want to have manuals and ACRs seem expensive or atleast the tools are so I figure the work is expensive at the dealer. I also don't want to lose my nice head bolt bridge cover things if I go manuals. Manuals may be what I end up with though. If you have stock heads now why not switch to the new ACR heads and have them ported?
The link says they modify plugs to work with these. They use NGK and Autolite, additional plugs are $25 a piece. If it moves the electrode up in the hole at all I would say no go. I think you would run into issues with that. The plug needs to be in the hole firing not up in a hole.
Old Jan 29, 2013 | 07:18 PM
MikeTD3's Avatar
MikeTD3
Not going to happen this year; first kid in college this past fall and I'm bleeding $$$
agreed..i sent them an email asking for clarification on this.
Old Jan 29, 2013 | 07:33 PM
Notgrownup's Avatar
Notgrownup
I have a MCR (HD one) in the rear cylinder and it helps...they did it without removing the head...
