Cruising AFR
Old Apr 15, 2015 | 10:03 AM
95ci springer's Avatar
95ci springer
Default Cruising AFR
What is the perfect AFR for cruising at highway speeds? Best for cool running and fuel milage?
Old Apr 16, 2015 | 05:52 PM
Pewter's Avatar
Pewter
It's complicated but usually 14.7:1 in closed loop. The richer the mixture the cooler but then less mileage. See if this helps.
http://www.endtuning.com/afr.html
Old Apr 16, 2015 | 06:41 PM
Webo's Avatar
Webo
I have my cruise RPMs set at 14.0 for extra cooling and I get about 40mpg.
Old Apr 17, 2015 | 12:03 AM
N U K E's Avatar
N U K E
No reason not to be in closed loop.
~ .980 lambda is what I run.
Old Apr 17, 2015 | 04:57 AM
Tn.Heritage's Avatar
Tn.Heritage
What afr is 980 ?
Old Apr 17, 2015 | 06:02 AM
timbo141's Avatar
timbo141
Hope this helps
Wow did this from my phone, sorry for the size of the picture, you don't need your "readers" for this one...
Old Apr 17, 2015 | 06:13 AM
95ci springer
My 2015 flhtk never got over 35 miles/gallon. Even all stock.
Old Apr 17, 2015 | 09:25 AM
Vernal's Avatar
Vernal
AFR = Lambda x Stoichiometric or Lambda x 14.7
Old Apr 17, 2015 | 10:54 PM
gwellis's Avatar
gwellis
14.6 in AFR or you are no longer in Closed LOOP. (no automatic adjustments by ECM) Run 14.6 in cruising mode for best burn. Enrichen @ lower RPM and full throttle positions. Read the ECM threads to get educated.
Old Apr 18, 2015 | 12:16 AM
N U K E's Avatar
N U K E
Closed loop is between .976 and 1.012 lambda. 14.34-14.87 AFR
