I have changed my primary fluid on this bike 4 times before, never an issue. this time, for some reason, the drain bolt will not seal. I have replaced the O ring multiple times, used Hylomar, regular thread sealer, and even teflon tape, and it still leaks.I swear it must be coming from someplace else, but I don't see any wet spots anywhere else.
Has anyone ever used an automotive drain bolt with a crush washer on this hole? I am running out of ideas...
thanks everyone. I think the folks talking about weeping out of the shaft seal were right. I was trying a new primary fluid that was much thinner than my normal primary oil. I think it was just too thin and weeping past the seal. Anyways, I changed back to my normal primary fluid, went for a ride, and dry as a bone. Weird I know, but thats what it seems to have been
