Removing Complete Fork Assy. 2014
Old Sep 26, 2014 | 05:03 PM
06SGWA's Avatar
06SGWA
Default Removing Complete Fork Assy. 2014
On the new models, do you have to remove the top cap before removing the fork assembly? I don't have it torn apart right now so, without seeing things, I was wondering what I will be encountering.
I read somewhere that the pinch bolts were all that needed to be loosened and it will all slide out. Is this true?
Thanks.
Old Sep 26, 2014 | 08:56 PM
02BlueDeuce's Avatar
02BlueDeuce
Yep. loosen the upper pinch bolts but don't remove and hold onto fork slider and loosen lower pinch bolts, then slide the fork tube out. Manual also says if necessary remove the slider covers.
Old Sep 26, 2014 | 09:01 PM
p51bombay's Avatar
p51bombay
Top caps are 19mm hex and flit flush - remove the ignition switch cover and you'll have access to the pinch bolts.
Old Sep 26, 2014 | 10:15 PM
pepe3rd1's Avatar
pepe3rd1
Curious, what are you doing to front end?
Old Sep 26, 2014 | 10:46 PM
nevada72's Avatar
nevada72
Hopefully something like this -
It really transformed the bike.
Old Sep 27, 2014 | 12:49 AM
06SGWA's Avatar
06SGWA
Yep, forks are going to powdercoater. That was much easier than I thought. I initially figured the entire fairing would have to come off but nope, just the switch cover. 3 allen bolts and they're off.
The bike is tore down again and I'm on my 2nd batch of stuff to coat. The only things left to remove are the rocker covers and pushrod stuff. I'm going to do some reading but I might have someone else do that work. That's what I said about the forks too though.
Thanks for the help guys.
Spazz
2014-2024 Touring Models
53
Jan 8, 2018 11:49 PM
Michaelkristensen
Jan 15, 2013 03:39 AM
traveler
Sep 17, 2011 10:55 PM
hell hound
Jan 16, 2010 04:35 PM
2K1FLHPI
Oct 12, 2009 11:24 PM
