Fork adjustment to lower?
Old Oct 11, 2014 | 11:20 PM
DD Dont's Avatar
DD Dont
I slid my forks on my 14 SG and havent had an issue. 1 up, 2 up, city, highway, corners... so far so good.
Not saying it CANT happen, just saying in 3000 miles of diverse riding, it hasnt.
Old Oct 12, 2014 | 01:36 AM
Brykwil's Avatar
Brykwil
15,000 miles after sliding my forks up on my 2014 FLHTK with NO issues. Some good sized potholes and a big rock the size of my hand at 5mph.My bars are 1-1/2 diameter so not as low as someone with bars 1-1/4 obviously.
One inch lowering blocks in the rear.(No issues)
Old Apr 24, 2015 | 09:05 PM
Racin929's Avatar
Racin929
6 months old, but I have to ask. How was the forks slid up? Just loosen the triple tree bolts?
Old Apr 25, 2015 | 05:39 AM
nsdhoward45's Avatar
nsdhoward45
Talking
Originally Posted by LilWick
You can't determine clearance with the springs removed...when coil bound the springs themselves act a as a stop. Of course with the springs and guts removed the lower legs will collapse. Cycle the forks till they stop with the springs installed and see what you get for clearance.
What he said !
Old Apr 25, 2015 | 05:37 PM
nsdhoward45
Originally Posted by SafetyMan
Howard Messner said it cannot be done. Call him and ask, he IS an expert, not like most of the "members here"
Howard Messner, www.motorcyclemetal.com
Phone #: 1-954-848-1525
~Contact via e-Mail~
use my own e-Mail: howard@motorcyclemetal.com
http://www.motorcyclemetal.com/contact.html
Yes I agree with Howard and SafetyMan (under no circumstance run tour front end without the springs installed ) SEE Post#4
It will diffidently bottom out.
however if you want to move your your fork tubes up 1 inch (ish) you can do it by only loosening the aux switch panel under ignition switch and then loosen the six (three per side)pinch bolts and that will allow the fork tubes to slide up to make contact with the handle bars (they will act as a hard stop ) you cant go to far 15 minuit job
Mchad
Aug 22, 2018 01:42 AM
eraldo64
Touring Parts
Apr 18, 2015 01:29 PM
traveler
Dyna Parts
Feb 16, 2013 07:34 PM
fenderzig
Oct 26, 2012 02:50 PM
FXD2003Rider
Sportster Parts
Aug 28, 2010 02:57 PM
