This happened to me when I was changing bars. The complete switch will pull out with the small key and turning a little beyond the lock position and pull it out. If you can get the complete switch out and nothing is oviously broken, flash light look down into it. I think there is 3 keys or slots down in the switch hole. You can find the right size flat head screwdriver and realign them. Put the switch back in and try it. At first it makes no sense but as you fiddle with it, you'll figer it out. Hope that may help a little, just sayin it can be done with out the dealer good luck.[/QUOTE]
I don't know that this will help but try wiggling the bars to remove the pressure from the fork lock pin.
I pulled the complete switch out and took it to the dealer. the locking pin for the forks was stuck extended and no amount of pulling, twisting, or yanking would remove the lock **** from the switch housing. The dealer ordered a new one via warranty, but thanks anyway.
One thing a bout the '14 up bikes that is nice is that you can remove the fairing cap without pulling the switch since the cap is slotted, did it a couple times. No way you could do that on earlier models.
Dealer installed new switch today and all is good again. The only thing I found that when unlocking the forks the **** will not just pop up after the barrel key has been turned to the unlock position. I have to pull up on it to unlock the forks. Pulled it out to make sure the spring was in place and it was.
Not a big deal to pull up on, but my 08 would just pop up with a key turn. When I first tried it, I thought oh crap! Here we go again.....LOL. But just a little tug and it pops up to unlock. I don't lock the forks except when on a trip where I will be in a room for the night. Camping I never lock it. Maybe it will loosen up after awhile.
Once and awhile mine doesnt seem to want to turn but then all I have to do is turn the handlebars a little while I turn that switch and it moves out of the lock position easily. Has also happened in the car where you can't turn the key until you turn the steering wheel hard. Not sure why it happens, only guess is that there is some pressure on that switch and once you relieve that pressure it free to turn..
