Removing the Cat
Old Jan 26, 2015 | 10:52 AM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
Originally Posted by Not Ed
I have the stock air cleaner, Screaming Eagle Street Cannons and factory tune.
on a 2014 limited.
If I decat my OE pipe do I need to have a stage 1 tune installed
Thanks
Opinions vary greatly on this. You don't necessarily have to have a tuner since you are only modifying the exhaust. However, Harley's come from the factory lean so it would not hurt if you did add some type of fuel management such as the Xied's or a Power Vision. Hope this helps you out
Below is also a Overview of EFI options, it has many different options.
https://www.hdforums.com/forum/ignit...uning-etc.html
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old Jan 26, 2015 | 12:02 PM
p51bombay's Avatar
p51bombay
Originally Posted by alarmdoug
For the ones who have tried with and without the CAT, is there truly a noticeable change in the amount of heat on the right leg?
I know its been commented on a lot but answers seem to be all over the place.
The difference at the cat with vs without is about 300˚F
Old Jan 26, 2015 | 03:34 PM
Not Ed's Avatar
Not Ed
my plan was to reduce the heat, I knew it would be some louder but don't want it to sound like "pooh"
Old Jan 26, 2015 | 08:44 PM
alarmdoug's Avatar
alarmdoug
Thanks everyone, great to hear about the heat reduction, I know, sooner or later by the time the warmer weather gets here Im going to get rid of it or check out a new set of headers.
Old Jan 26, 2015 | 11:47 PM
joenash's Avatar
joenash
Default tune
Kelsey
I followed your link and read up on it some and it seems the power vision is a good one to go with if you are a beginner in the tuning of your fuel injected motorcycle cause it has the auto tune feature, is that right?
Old Jan 27, 2015 | 12:18 AM
KMC1's Avatar
KMC1
Great info, thanks!
Old Jan 27, 2015 | 09:51 AM
DK Custom - ST
Platinum Sponsor
You are right, and even if your not a beginner. Devin and Kevin (DK) both have the Power Vision on their bikes and love them! As the Power Vision does have the auto tune feature it still comes with a pre-programmed EFI map for your bike. If you have any other questions feel free to ask
Kelsey
Old Jan 27, 2015 | 09:53 AM
Betteroff's Avatar
Betteroff
Waaaaay less heat after de-cating mine!
Old Jan 27, 2015 | 10:16 AM
OldPhat's Avatar
OldPhat
For about $120.oo Nightriders Fl-ViED-10 with adjustable Air Fuel Ratio will work for you.
Old Jan 27, 2015 | 10:28 AM
Betteroff's Avatar
Betteroff
That's what I'm using....Got mine on Amazon for a little under $100 last year.
