I'm running the TTS Mastertune and just had a Dyno tune done Tuesday. The tuning run only took 2 hours and I ended up with 84.57 HP and 104.97 TQ. Very pleased with the results. Cost of the Dyno tune was $251.54. I added head pipe, Big Sucker and TTS Tuner. No cams...yet.
You do NOT need the TTS hooked up to a laptop to data log.
TTS used to make the older better version of the SE tuners for the moco. Later Harley has someone else make it. TTS puts out their own without all the limitations Harley was putting on them and released the TTS Mastertune.
TTS just relaeased Vtune 3 which makes VE, TIMING, and EGR adjustments automatically after data logging. IDK what the other tuners can do i have not looked back after buying the TTS and haven't heard of anyone saying they went from TTS to anything else and was happier. The Vice versa i cannot say.
Cheers
Webo I have been doing the autotune and the bike still seems lean. When you want to make it richer , is it better to make the VE Table numbers higher, or adjust the AFR ?
Casbar I have been having a little difficulty getting it in tune, I had some questions in the SEPT tuning section of this fourm but no replies. what modifications do you have done to your bike?
All I did was load a map that one of the members on here sent to me. He had several maps that he had got from tuning other bikes. The one I loaded worked great.
