Dyno chart post
Old Jun 3, 2015 | 11:37 AM
CapeGlide's Avatar
CapeGlide
Default Dyno chart post
This is a follow-up to a recent post on my Dyno numbers. Some were questioning the results, this is the first Dyno I've had done and I'm really thrilled with the results. I have a 14' Limited with 103, Fuelmoto head pipe and tuned exhaust and a power commander tuner. The chart is saying peak tourque at 118 and hp at 97. What am I missing here? Are these results questionable? Thanks guys.
Old Jun 3, 2015 | 11:45 AM
FNGonaRK's Avatar
FNGonaRK
Those are impressive numbers for such a modest list of mods.
Old Jun 3, 2015 | 12:04 PM
cpbedor's Avatar
cpbedor
Your HP number seems only slightly inflated. Certainly attainable with a giddy Dyno. Your TQ number is super questionable to me. I have a stage 4 with Baisley SS Heads, high compression pistons, 58mm throttle body and t-man 660 cams with a D&D fatcat and my tq number at initial tune was 119. So either the Dyno was very generous or FuelMoto is about to have a rush on their head pipe and they should increase production immediately.
That said, numbers are just numbers. If you like it and you're happy with it, that's all that really matters.
Old Jun 3, 2015 | 12:12 PM
fattybob's Avatar
fattybob
Could this be because the dyno used 'standard' smoothing, which may be up to 4% higher than SAE smoothing?
Old Jun 3, 2015 | 12:16 PM
cpbedor's Avatar
cpbedor
even 4% lower puts this at 113 tq. and for a stage 1, that's a heck of a stretch.
Here's my Dyno sheet from a Stage 1 with a VH Power Dual pipe and a TTS mastertuner. 86/103. The big motor work was done the following October when it was snowing here!
Old Jun 3, 2015 | 03:03 PM
fattybob's Avatar
fattybob
You are still better than my '14 FLHTK (81hp/95tq). I also have the power duals, but used a SEPST for the dyno tune. My mufflers are V&H twin slash ovals and I have an SE ventilator AC. I would have thought my numbers would be a bit higher. Anyway the bike seems to have enough power and runs well.
Old Jun 3, 2015 | 03:26 PM
CapeGlide's Avatar
CapeGlide
I can only tell you how well the bike runs since the Dyno, I couldn't be happier. I'm a pretty aggressive rider and the bike responds much better than it did with just the stage 1.
Old Jun 3, 2015 | 07:33 PM
68 XLCH's Avatar
68 XLCH
My dyno was 87.48 HP and 106 torque.
Your numbers for stage one do seem high, but i am certainly no expert.
If they are correct, i'd say fuelmotto/powercommander is the way to go.
Old Jun 3, 2015 | 09:08 PM
Springerfan's Avatar
Springerfan
Default Dyno
I don't have my dyno sheet handy but my 14 SGS with S&S Power Tune Dual headers, SE Agitator AC and 4" Rineharts with competition baffles was 86.8 hp and 103.4 tq which is in line with most others with the same mods. An SE pro tuner was used for the tune.
Old Jun 3, 2015 | 09:28 PM
Roadglide33's Avatar
Roadglide33
No way you get those mumbers with your mods... Something is very fishy...
