Air shocks/pump
Old Jun 18, 2015 | 01:36 PM
dave k.'s Avatar
dave k.
Default UPDATE and Not so Good
Ran home at lunch and hooked up the pump pretty tight, it read Zero. I put air in and again, it only takes 30lbs. I watched the gauge slowly creep down. The suspension is Not holding air. Called dealer and they want to see it. Bike has just above 700 miles.
Old Jun 18, 2015 | 05:07 PM
Vernal's Avatar
Vernal
Sounds like a warranty issue.
If you're interested in locating the problem there are 4 tubing connectors, 2 where you hook up your pump and one at each shock. Mix a little liquid dish soap with water and put it around the connector and look for bubbles. Even check the air valve you hook the pump to. Maybe the tubing isn't pushed in the connector far enough. If no indication of a leak maybe there s a rub somewhere that's leaking. Might save you a trip to the dealer
Good Luck
Old Jun 19, 2015 | 06:43 AM
dave k.'s Avatar
dave k.
Yes that was the problem, one connector was leaking. I wasn't too concerned once I got home and could spend a minute looking at it. I still ran the bike up and the dealer replaced it but all in all I could of fixed it as well.
Thanks for the reply's I absolutely Love this bike!
08ClassicRider
Air Suspensions
Jan 19, 2021 07:39 AM
30glock
2014-2024 Touring Models
Jul 6, 2015 06:35 AM
bba
17
Apr 16, 2014 10:46 AM
PDDGM
Apr 1, 2012 04:05 PM
k-hook
Feb 8, 2011 08:55 PM
