Air shocks/pump
Curious about this, any thoughts?
Thx Dave
Thx Dave
Thx for the responses, I was hoping I didn't screw up the air shocks in any way.
If that's the case, I'm sure it shouldn't be a problem to swap it out at the dealer.
Solo, I ran 14-15lbs on my 2011, I was 260-265 back then (AND I'm back there now
Two-up, I ran it up to 25lbs.
If you're not bottoming out, you're not running it too light, and the more you put in, the stiffer your ride. You want it where it has as little air as possible, and not bottom out. That's the mistake a lot of guys make, and the reason a lot of guys find it necessary to spend boo-koo bucks on shocks is they are stuck on numbers, rather than dialing them in.
