Boom system problem, I know big shock
Old Jul 8, 2015 | 12:00 PM
Bayoudude's Avatar
Bayoudude
All I saw was scan. I tried to reset it from the usb menu. I have never had any problems with the system. The only problem I had was the volume control wouldn't work all the time. Once I learned to not start the bike until it had booted up all the way I had no more problems. I might add I haven't done any updates. It's not the 6.5 system so I figured I didn't need to update anything.
Old Jul 8, 2015 | 12:28 PM
caberto's Avatar
caberto
OK... I just went to the garage and fiddled with mine - it's a 6.5 but should function the same I think... while your radio is playing from the USB, and the display is showing the song being played, select Menu. This will bring up some options... One of the options toggles between "Presets" and "Seek". Below that is the Scan button - leave the Scan button alone. You probably only see the "Preset" button, press that "Preset" button and it will change to "Seek". Your left toggle lever should work now to go to the next song. Hope this helps.
Old Jul 8, 2015 | 01:24 PM
zoozoo's Avatar
zoozoo
There is so much to remember you really have to play with the infotainment on a daily basis or you will forget how to use it. For me that's call oldtimers.
Old Jul 8, 2015 | 01:26 PM
-RocknRoll-'s Avatar
-RocknRoll-
This^^
On a side note reading the manual a little each night, right before I get some shut eye has helped enormously in discovering options I didn't know existed on this somewhat confusing audio system. Hope you figure it out!
Old Jul 8, 2015 | 01:45 PM
Bayoudude's Avatar
Bayoudude
Thanks for everything. Once I pushed the preset button it changed to seek and all is well. I never fool with that stuff so I don't know all I should. That is a good thing but it can be bad as well. It was going to be a long ride to Sturgis without being able to change songs
Old Jul 8, 2015 | 03:35 PM
robertd's Avatar
robertd
Default Boom system problem, I know big shock
DAMN! F**g glad I don't have a radio on my ride
latrappe
EVO
34
Nov 7, 2017 02:59 PM
Nobby1970
2014-2024 Touring Models
May 1, 2017 03:15 PM
WARDSPARTSWERKS
Aug 5, 2016 01:51 AM
slowrollin
Apr 23, 2016 01:57 PM
ezgary
General Topics/Tech Tips
Apr 29, 2009 08:35 AM
