Redirecting Blow-by
Old Sep 24, 2015 | 11:23 AM
jayhawkclint's Avatar
jayhawkclint
Default Redirecting Blow-by
My '14 Electraglide has some blow-by. It was leaking all over the timing cover and burning on the exhaust, so I took it into the dealer on warranty. They said the amount of oil was "within limits" (I personally think it is more than a brand new bike should have), so they put a new rubber hose in the air cleaner and sent me on my way. While it did fix the oil dripping down the side of the bike, I now have a get a pretty good smell of burning oil whenever I come to a stop once I've been running the bike for a while.
Anyone vent their oil breather line down to the ground to prevent this? Thinking letting it drip is better than smelling it burn. Other than a little extra corrosion preventation oiling the bottom side of the bike, any draw back to this method?
Old Sep 24, 2015 | 11:26 AM
perki48's Avatar
perki48
I can not really answer your question but will ask you one instead. Are you absolutely positive that your bike has not been a little overfilled with oil?
Old Sep 24, 2015 | 11:39 AM
Msquad's Avatar
Msquad
Waaay better for the engine to not let that hot oily air back into the motor. Many threads around here about rerouting. One of the 1st things I did was reroute my breather hoses.
Old Sep 24, 2015 | 12:16 PM
jayhawkclint
Yes, absolutely sure. I do my own maintenance. I've even tried running it a half quart low. Still has blow-by.
Old Sep 24, 2015 | 03:51 PM
larry bart's Avatar
larry bart
Find another dealer!!! Acceptable amount of oil leaking. That's a good one
Old Sep 24, 2015 | 04:16 PM
ridertomk's Avatar
ridertomk
Stage II
Is it possible you still have oil film on the engine from the original moment it happened? Try spraying down the area and underneath with Simple Green and hose it off. I run the oil level on my 2015 FLHTKL at the halfway point on the "safe" range of the dip stick (that's the way it was delivered too). I've never had blow-by or dripping in 8,500 miles so far.
Old Sep 24, 2015 | 05:04 PM
RG Pilot's Avatar
RG Pilot
I have no oil whatsoever in my air cleaner and never a drip. I have the HD Screamin Eagle stage 1 air filter kit which includes the integrated breather bolts and before that with the stock filter, no oil either. I too fill only to half way up the dipstick's normal range and I believe that's at least half the problem with most. If you only fill yours that high, then you could have a ring seating problem but good luck with talking them into fixing that.
Old Sep 24, 2015 | 05:11 PM
lp's Avatar
lp
I pretty much expect blow-by just about no matter what. In 6 bikes all with various levels of oil, never fails, just does it.
I still don't understand how the level of oil in a remote oil bag/pan in which the oil is pumped to and from affects blow-by in the actual engine, but it surely does somehow considering all the people who post better results running the oil level low.
Old Sep 24, 2015 | 05:22 PM
the_ogre25's Avatar
the_ogre25
For those that have ran a hose down does it hurt to run it up along the the top of the frame to hide it some. The hose running down by the lifter block just doesn't look good to me.
Old Sep 24, 2015 | 08:04 PM
jimmy1439's Avatar
jimmy1439
Fought this issue for a while. I thought I had it beat by running the oil low, but it came back. I got a DIY Breather Kit from DK Customs (site sponsor) and it did the trick. Well worth the money, installed in about an hour.
