Daymaker Install Question
Old Jan 28, 2016 | 10:18 AM
Dynamite17's Avatar
Dynamite17
Default Daymaker Install Question
My 2014 RK has the original headlight and I am going to install the Daymaker. Can I expect the alignment to be OK for this headlight if it is OK now?
Bob
Old Jan 28, 2016 | 11:06 AM
Seventy4blazer's Avatar
Seventy4blazer
you shouldn't mess with the adjusting screws at all, so it will be close, but you will have to adjust it a bit.
Old Jan 28, 2016 | 12:28 PM
Magnut1's Avatar
Magnut1
What I have read is the original headlights are set to the low side and those of us the went with daymakers usually have to raise it up a bit.
Old Jan 28, 2016 | 12:50 PM
Dynamite17's Avatar
Dynamite17
Sorry, just a bit confusing. If I dont mess with the adjusting screws, how will I adjust it?
Old Jan 28, 2016 | 01:46 PM
TcHunter's Avatar
TcHunter
Bob
No I personally would not expect it.
To get the best visibility out of your Daymaker you should adjust or at least make sure it is angled where it needs to be, that is the reason why your swapping it out.
Your manual should tell you how.
On the SGS you need to be 25 feet from a wall on a flat surface the center of the headlight should be the same height as the measurement from the ground to the center of the light. I don't know if it is the same rule for your Road King, but again it should be in the manual.
Did you get the Daymaker projector?
or the Daymaker Reflector?
Old Jan 28, 2016 | 01:57 PM
Dynamite17's Avatar
Dynamite17
The Projector (#67700241) $399 no tax & free shipping. $100 less than my dealer. $16 for the adapter. (Not interested in a debate regarding other brands etc...)
Old Jan 28, 2016 | 02:29 PM
TcHunter's Avatar
TcHunter
Good price, but again I would highly recommend adjusting that light, it makes a huge difference when the projector Is adjusted properly.
Actually its a must, otherwise you will not be happy with it. JMO
Old Jan 28, 2016 | 04:20 PM
Seventy4blazer
Sorry, I should have been more clear. On installation, you shouldn't mess with the adjustment screws.
Old Jan 28, 2016 | 04:26 PM
CVO SG's Avatar
CVO SG
Mine was same with the Daymaker. Very disappointed in light output for the cost.
Checked alignment per HD manual, way low from HD. Night and day difference once adj correctly
Old Jan 29, 2016 | 10:51 AM
05dlx's Avatar
05dlx
Put on one my '14 SGS no problem, its as easy as removing the OEM light and putting this on in its place along with the wiring harness. Easy Peazy... Not need to mess with the adjustments as all. Your light should shine in the same location as the OEM only better!!!
SkullsAndChrome
Jun 8, 2018 08:14 AM
Casper
Jun 10, 2015 08:20 PM
ZenGlide
May 21, 2015 11:11 AM
IornStreetBob
Mar 2, 2015 08:38 AM
danengr
Electrical/Lighting/Alarm
Aug 4, 2012 01:03 PM
