Modify stock a/c?
Old Feb 4, 2016 | 10:15 PM
DCRANER's Avatar
DCRANER
Default Modify stock a/c?
On my 2015 SGS, I have the DK Custom breather, K&N filter, and am adding the Jackpot header pipe and FuelMoto download. Looking at the FuelMoto, Zippers, etc. a/c kits I don't see a significant difference in the a/c housing other than two large oval openings.
So, not being cheap but why can't I just cut similar openings in my stock housing?
Old Feb 4, 2016 | 10:31 PM
FlyingSkeet's Avatar
FlyingSkeet
I think the FuelMoto numbers show that a stock air box will flow all the air you will ever require with 103 jugs.
Old Feb 4, 2016 | 10:43 PM
Racin929's Avatar
Racin929
I have the k&n element in mine. Fuel moto micro tuner and download. For what its worth, the fuel moto download for my tune with k&n element is the same for a big sucker per fuel moto.
Old Feb 5, 2016 | 03:58 PM
GibsonSG's Avatar
GibsonSG
If I hadn't swapped throttle bodies...I'd still be running a stock AC cover with a K&N element, you'd be hard pressed to have that become the 'weakest link'.
Old Feb 5, 2016 | 06:26 PM
OldPhat's Avatar
OldPhat
Might think about drilling some 1/2 inch holes into the back side of you air box.
I with a lot of others on this forum that think a K&N filter in your Rushmore AC housing
will flow all the air a Stage-I or II can use.
Old Feb 6, 2016 | 12:11 AM
Racin929's Avatar
Racin929
If fuel moto doesnt have to change a map from just a K&N filter to a big sucker I would think that it would be enuf too.
Old Feb 6, 2016 | 08:57 AM
ROCKOUT Rocker Products
Sponsor
Couple things....
The stock airbox should flow all the air your bike needs. Someone who knows of such things told me there IS a little to be gained by removing the screen if you need more.
Second, the stock housing does a great job of keeping the intake noise in, and there's a lot of it. I sold a Ness Big Sucker with the open back 'cause the intake noise drowned out the exhaust noise.
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
hapbob
2014-2024 Touring Models
14
Mar 30, 2015 01:14 PM
C908
Nov 18, 2012 09:00 PM
Dirtball
Aug 7, 2012 03:37 PM
papejr
Aug 5, 2012 02:12 AM
2009 FatBob
May 24, 2009 09:06 PM
