Pressure?
Old Apr 17, 2016 | 08:52 PM
digdug's Avatar
digdug
Default Pressure?
I am running a metzler 880 me 120/70/21 on the front of my 2015 SGS. Can't see the pressure on the sidewall. Looked at metzler website and they have all of their sizes listed in one long sentence super confusing.....can somebody just tell me what psi to put in this tire? Thanks people
Old Apr 18, 2016 | 01:36 PM
02BlueDeuce's Avatar
02BlueDeuce
I'm running the Dunlop 130/60/ 21 and it takes 36 psi just the same as the stock 19 Dunlop that came on the bikes.
Old Apr 18, 2016 | 02:32 PM
Greatsteaks's Avatar
Greatsteaks
Don't go by what the sidewall says, that's max. 36-40 adjust to your likings.
Old Apr 18, 2016 | 02:39 PM
MilesOfTexas's Avatar
MilesOfTexas
Recommended tire pressure is listed on the plate/sticker on the left side of the bike on the down tubes near the neck. Like Greatsteaks mentioned, sidewall is for maximum.
Old Apr 18, 2016 | 03:02 PM
digdug's Avatar
digdug
I can't go by what the sidewall says cuz I can't find it on there. I guess I have to look harder. Also the plate/sticker on the downtube is for the stock tires isn't it? This is a custom wheel with a different height/width tire than stock. Thanks for the help though.
Old Apr 18, 2016 | 03:44 PM
MilesOfTexas
The plate/sticker is for all tires as long as the tires are OEM size. The pressure is determined by the manufacturer for the weight of the vehicle and the stock sized tires. Just like a car or truck has the pressure listed on the sticker inside the driver's side door jamb.
However, if you change the tire size, that changes the physics of how much air pressure you need in order to have the proper size contact patch between the tire and the pavement.
Also, just like cars/trucks, when there is extra load, more air pressure may be required. The sidewall will only give you max pressure and you should only need to go that far if load requires it. You should also be able to find the max pressure of the tires on the manufacturer website.
Old Apr 18, 2016 | 03:48 PM
MilesOfTexas
Here is a link that may help you:
https://www.hdforums.com/forum/softa...a-21-inch.html
Old Apr 18, 2016 | 03:51 PM
MilesOfTexas
From Metzeler:
http://www.metzeler.com/site/us/tech...intenance.html
"You will find the correct pressure in the operating manual of the motorcycle."
Old Apr 18, 2016 | 07:54 PM
legoiii's Avatar
legoiii
I have the same tire and I run 40psi
nikonf8
Jan 25, 2024 05:34 PM
wyotana
May 24, 2014 11:38 PM
Stag556
Aug 10, 2012 08:14 PM
stonewall308
Jan 23, 2010 06:54 PM
anubisss
Dec 11, 2008 10:28 PM
