Front plug wires
Old May 26, 2016 | 07:33 PM
  #31
GalvTexGuy's Avatar
GalvTexGuy
Originally Posted by vizcarmb
Thanks for the heads up here. Ill definitely look at mine now. But for you guys that complain about the littlest type of ****, please stop, you are embarrassing yourself. People like me dont have the time to take their bikes to the dealers a complain about something as stupid as wires rubbing on a tank. If you see it then fix it. This is why we have forums to let everyone know about simple fixes like these.
Right? I mean are you guys that weak?
[cough]troll[/cough]
Old May 27, 2016 | 09:47 AM
  #32
alarmdoug's Avatar
alarmdoug
My front plug wire is chaffed. I noticed it after reading about it in the forums. Someday will bring it to the dealer and get it replaced under warranty.
Old May 27, 2016 | 10:09 AM
  #33
Tanker2's Avatar
Tanker2
Does the tank have to be removed to see the damage? Or can it be fixed without removing the tank?
Old May 27, 2016 | 10:21 AM
  #34
hbsoldier3's Avatar
hbsoldier3
No and Yes
Old May 27, 2016 | 10:30 AM
  #35
GalvTexGuy's Avatar
GalvTexGuy
Depends on what you mean by "fixed". If you mean zip-tied to keep it from rubbing, no tank removal. If you mean replacing it and securing it properly, tank removal or loosening it and propping it up.
Old May 27, 2016 | 11:08 AM
  #36
Tanker2's Avatar
Tanker2
Thanks. Already looked at it. Can be fixed without removing tank. Mine has 2700 miles on it, not a problem yet. But it could be. This is why it good to read the forum once in awhile.
Old May 27, 2016 | 04:23 PM
  #37
Watchfuliz's Avatar
Watchfuliz
My 2015 just turned 20,000 and I never noticed the wear, but it is there. Black fuel tubing split and zip tied is just too easy a fix. I'm all about the KISS plan. KEEP IT SIMPLE STUPID.
Good for another 100K now.
Old May 27, 2016 | 09:08 PM
  #38
Don81's Avatar
Don81
Originally Posted by jlasoftail
While I agree with you that people should be fixing that stuff themselves, I will say that I had zero interest in paying for the new plug wire. I didn't have the bike for a month and it was near worn through. I would have been just as happy to walk away with the new wire in my hand and not on the bike.
Honestly it isn't the fixing, it's just paying attention. I figure once you had the dealer fix it you took a peek to check that the wire is safely off the tank am I right? You don't just leave the dealer in condition white, head in the clouds assuming everything is dandy.
Obviously there are reasonable limits. If you had your transmission rebuilt by the dealer I don't expect someone to be checking countershaft end play. But for things like this, you can just as easily check to confirm it's fixed as you can confirm you have the issue in the first place, so there's no excuse for leaving the dealer without it fixed.
Lol I guess I still can't get over that guy running on low brake fluid for 25,000 miles. I mean come on, there's a ****ing sight window!
Old May 27, 2016 | 09:10 PM
  #39
Don81's Avatar
Don81
Anyway, I can confirm that bending the plug wire terminal some more does get the wire well off the tank. I've got split loom on there anyway but it probably isn't necessary.
Wisenheimer16
2014-2024 Touring Models
23
Jul 12, 2019 05:02 PM
Chuck Downey
Oct 1, 2017 02:46 PM
pokey074
May 19, 2017 08:08 PM
GBHummer125
Jan 10, 2015 09:48 PM
ShadowSoldier777
Aug 15, 2010 09:54 PM
