Rear Tire Replacment
Old Jul 15, 2016 | 07:51 AM
Gwaxley's Avatar
Gwaxley
Default Rear Tire Replacment
Do you remove the exhaust or thr shocks to remove the rear axle and tire and is there a measurement of how much slack or play can you have in the rear sprocket and dampeners Thanks
Old Jul 15, 2016 | 07:54 AM
rwven's Avatar
rwven
I pulled the right muffler and removed the two bolts in the hanger on the left muffler. I don't see how you can adjust the belt tension properly on reinstallation with the shocks off.
Old Jul 15, 2016 | 08:19 AM
markdavidson's Avatar
markdavidson
I drop the shocks and let the left side exhaust rotate down.
I set my belt tension with my lab calibrated finger, put it all back together and on the ground then verify tension again.
the belt tension hasn't changed for me
Old Jul 15, 2016 | 09:26 AM
rwven's Avatar
rwven
So that's where I went wrong! I bought one of those belt tension scale things....
Old Jul 15, 2016 | 09:58 AM
markdavidson
LOL yeah, I got one of those too
Old Jul 15, 2016 | 03:45 PM
robbie52's Avatar
robbie52
If you have oversize mufflers, you have to remove both mufflers to remove axle and re-torque during installation. There is not enough room to use a thin wrench to hold axle nut without hitting the right muffler.
Old Jul 16, 2016 | 07:43 AM
Schaub85's Avatar
Schaub85
I have D&D fat cat. I was able to get my rear wheel off and back on without removing shocks or exhaust.
Old Jul 16, 2016 | 09:32 AM
14GuineaPig's Avatar
14GuineaPig
I usually remove both mufflers. I unbolted the shocks when I did my last tire change but the next time I'll go back to removing the mufflers.
Old Jul 16, 2016 | 09:50 AM
ROCKOUT Rocker Products
Sponsor
On my Limited Low I removed the right muffler. It was stuck on so bad that in itself took as much time as r&r the wheel.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jul 16, 2016 | 10:01 AM
Shanebo's Avatar
Shanebo
When I changed out my stock pipes for S&S Quiet Tour slip-ons last fall, it took a significant amount of effort to remove them, due to the pipes having corroded onto the muffler flanges.
At the time, I coated the inside of the new muffler flanges with Anti-Seize compound, hoping to have an easier time in the future when removing them again.
Two days ago, I changed out the tires for the first time on this bike, and removing the mufflers was super easy, with zero corrosion, even after many miles of rain riding already this year.
So yes, I remove the mufflers when removing the rear wheel--makes everything that much easier to do myself.
All the best,
Shane
