Alternator output
Old Mar 18, 2017 | 10:56 PM
soonerp's Avatar
soonerp
Default Alternator output
So I need to run my portable 02 generator (copd) when i ride. I can use a cigarette lighter plug in and the unit draws 150 watts when charging its battery. Will the bike's electrical systems handle this much load? I believe the alternator on my 2015 FHLTK puts out 650 watts or 54 amps but I have no idea what the bike needs or what is in reserve. Help
Old Mar 19, 2017 | 07:24 AM
OldMike's Avatar
OldMike
Some touring models come with a high output alternator according to the Harley website, looks like the high output one is rated at 54 amps.
http://www.harley-davidson.com/store...A&gclsrc=aw.ds
For sure I would change to a high capacity battery and use the cigarette lighter plug while riding at speed, not idling in traffic. If the COPD is OK to plug into a car I would feel safe using it after changing to a good battery.
Amazon Amazon
Old Mar 19, 2017 | 07:35 AM
soonerp's Avatar
soonerp
Thanks Mike.
Old Mar 19, 2017 | 02:28 PM
matt76cmich's Avatar
matt76cmich
stock Rushmore stator puts out 50 amps. so I don't think you would really need the additional 4 amps for what they will cost ya.
Old Mar 20, 2017 | 06:57 AM
MilesOfTexas's Avatar
MilesOfTexas
Correct on the 4amps difference, however the high output gives you a lot higher output at idle. Without the high output, the higher load may start drawing more than the charging system can provide when in idle situations, such as traffic lights, congestion, etc.. That's the reason I upgraded to the high output on my '14 TK.
Old Mar 20, 2017 | 09:30 PM
soonerp's Avatar
soonerp
Any idea on what the stock bikes uses out of the 50 amps available I:e what's in reserve. Thanks for the info
Old Mar 20, 2017 | 09:54 PM
nevets61's Avatar
nevets61
I'd start with swapping out your headlamp, and all turn and brake lights with LED if they are not already. Each turn/brake lamp will save you about 1 amp, the headlight could save you 5-10 amps of load so that right there will support the COPD unit load.
Old Mar 21, 2017 | 05:39 AM
Cossack84's Avatar
Cossack84
It will be fine, 150 watts is a 12.5 amp load. As long as you don't expect to load her up with 500 watt amp too.
Old Mar 21, 2017 | 10:28 AM
soonerp's Avatar
soonerp
Thanks all
salty_rider
Apr 16, 2015 06:14 AM
eliaz
Electrical/Lighting/Alarm
Nov 27, 2014 08:48 AM
Shepherdboy44
Dec 18, 2013 04:05 PM
mesquite
May 3, 2013 10:17 AM
Rockabilly88
Feb 4, 2013 09:18 AM
