Front brakes squeaking
Old May 17, 2017 | 04:13 PM
pcmc2's Avatar
pcmc2
Originally Posted by pcmc2
I replaced the front brakes pads (both sides) on my '14 Limited because the old ones were squeaking. They were about 1/2 worn with around 8k miles on them. Now after only about 50 miles the new ones are squeaking. What gives? The rotors look fine and not grooved. BTW the back pads were replaced about 1000 miles ago when I replaced the back tire and they don't squeak.
Thanks to all who provided input. I thoroughly cleaned everything before I put the new pads on.
UPDATE: after riding about another 100 miles the brakes only squeak a little when I first "hit" them. Not too annoying now. I can live with that.
Old May 22, 2017 | 01:13 PM
pcmc2's Avatar
pcmc2
LATEST UPDATE: After a 650 mile weekend ride the rear brakes are now squeaking and the front brakes have a harmonic sounding growl to them. Both are very annoying! Grrr
Old May 22, 2017 | 01:22 PM
KrustyKush's Avatar
KrustyKush
For sure, brake noise is hard to bear. I can remember bikes of the 70's especially Harleys having real squealing brakes. But this has been gone for a long time, now that motorcycle brakes are so good.
There's something wrong with your brakes. It almost has to be the rotors, since you've replaced all the pads.
Good luck, keep at it, you'll find it.
Old May 22, 2017 | 06:31 PM
EasternSP's Avatar
EasternSP
I've never had any luck with Harley pads or rotors. The rotors warp within about 8K miles. I have found after market rotors to be much better. I had to put new rotors on my 16 RGU at about 8K miles. I couldn't find after market rotors this time so I had to go with H-D rotors again. The fronts are just starting to get the pulsing effect now at 21K.
Old May 22, 2017 | 06:58 PM
CSMHOG's Avatar
CSMHOG
Interesting. I have about 100,000 miles without one warped rotor. I wonder if the fact that you may ride on hills and I'm a flat lander. Just food for thought.
Old May 22, 2017 | 08:19 PM
EasternSP's Avatar
EasternSP
Not sure what hills would have to do with it. I would be quite sure H-D took that into consideration when they designed it. Besides, it's not like 45 degree inclines here. Most of my mileage is pretty much flat. I think it's just the BS cheapest thing they could make the rotors out of. Why is it most after market can figure out how to improve stuff within a few months of the new models hitting the streets?
Old May 23, 2017 | 05:47 AM
Notgrownup's Avatar
Notgrownup
I am on my 2nd set of HD stock at 95000 miles and looking for a set of good take offs...The EBC double sintered pads eat them up a bit so about 50000 is all I can muster out of the rain.
Old May 23, 2017 | 06:15 AM
rwven's Avatar
rwven
The rears on my Limited squeal also. The growl in the front you are hearing is likely caused by the perforations in the drilled discs. I put EBC HH pads on the front of mine and while they stop and feel better than the stock pads (IMO) they growl even more than the stockers. The rears will be changed to EBCs next time they need changing, I'll take the growl over the squeal any day.
Chuck1
Jun 23, 2017 12:36 AM
paid4c4
General Topics/Tech Tips
Feb 16, 2016 07:45 PM
RaceFace
Aug 2, 2011 04:39 PM
Figstr
Oct 27, 2010 08:23 AM
jasonh96
Wheels/Tires
Apr 4, 2010 09:08 AM
