Previous Software Updates
Old May 17, 2017 | 08:20 PM
IUOE ROB's Avatar
IUOE ROB
Default Previous Software Updates
O.K., just spent an hour of my life (that I'll never get back) searching for that list of all the past Boom software updates and can't find it, does anyone have it handy? Went for a ride today and had some issues with the latest (.4) update so I wanna revert back to the .3 or even the .1...TIA!
Old May 17, 2017 | 08:26 PM
Hinzy's Avatar
Hinzy
I have .1 &.3 pm me your e-mail
Old May 17, 2017 | 08:31 PM
IUOE ROB's Avatar
IUOE ROB
PM sent...thank you!
Old May 17, 2017 | 08:38 PM
Hinzy's Avatar
Hinzy
&%*K! Rob sorry to get your hope up,can't figure out how to attach the files.
I have gmail can't quite figure it out, hopefully someone will respond with a download link.
Sorry
Old May 17, 2017 | 08:45 PM
RollaMo's Avatar
RollaMo
Sorry
The update files are too large to send as an email attachment.
They need to be hosted on a file server.
Old May 17, 2017 | 08:47 PM
jeff53404's Avatar
jeff53404
Using Edge and Internet Explorer 11, I tried the old trick of right-clicking on the download tab and opening in new tab and neither works. If it did work, you would go to the url on top and change the address to 1.20.3. I have TOR available and that works. I don't have Firefox or any other browser installed but I suspect those will work.
Use TOR, or try FF, Chrome, etc. and right click on the download software and open in new tab. Click on download file and then click on the new tab and you will see the address on top. Change the file name to the last version. Note that this will work only if HD still has it on their website. Version 1.20.3 is still available.
Edit: It does work in Internet Explorer 11 but you need to right-click on download software and open in new tab. Click on that new tab and then you will be able to change the address.
Edit Edit: I did get it to work in Edge. Right-click on the download software but select "copy link". Then, paste the link in the address bar of a new window (or clear the text from the current address bar and paste). Then, adjust the name for the version you want If it says, file not found, that version is not available through HD.
Old May 17, 2017 | 08:48 PM
Hinzy's Avatar
Hinzy
Exactly what I found out and I'm not savvy enough for the latter
Thanks for pointing that out,hopefully someone will chime in
Old May 17, 2017 | 08:59 PM
RollaMo's Avatar
RollaMo
Yes, this still works as of right now.
Link for the 6.5 Premium:
http://www.harley-davidson.com/app-c...5GT.1.20.3.zip
Old May 17, 2017 | 09:05 PM
jeff53404's Avatar
jeff53404
Thanks. I forgot how much easier it is to just supply the direct link.
Old May 17, 2017 | 09:51 PM
MatteGlide15's Avatar
MatteGlide15
I'm still using the .1 version..... racked up a couple thousand miles with zero issues so till I hear of a version that can last that long or more without glitches, shutting off, freezing or whatever other crap that's been going on I'm good
