I am picking up a 2015 FLHTKL on Tuesday and have a question about changing the air cleaner. I have no desire to change pipes and am wondering if I need to have the ECU programmed for the installation of just the air cleaner, such as a Ness Big Sucker.
No, but you would benefit by adding an FP3. The engine already runs lean, so adding more air isn't going to make the bike run any better than with the stock air cleaner.
I wouldn't add a high flow filter without tuning, even if it does really have a completely stock exhaust. Unless you can verify with data that the stock air filter and stock exhaust are equally restrictive under all operating conditions, you may cause it to run leaner by changing one or the other without adjusting the AFR. I would add the FP3.
OP, quite certain for your application your install instructions on all high flow breathers will be clear, ALONE your ECM settings will require adjustments.
That said, if you combine the high flow breather with a auto tuner like the FP3 those setting will be flashed to correct the ECM. Hence ,no trip to a dyno for the adjustments. The best way IMHO.
Save your money and do a full stage 1, that's all you'll need. The motors are already running lean per the EPA restrictions. Your bike will love you and you will love your bike. Do a little homework and put together what you want; full exhaust (headers and slip ons), hi flow air cleaner, and fuel management program (TTS, PCV, etc...). You're probably looking at about $1500 for everything, IF you have some mechanical skill, for its fairly easy to do.
I'm confused, if the bike is running totally stock, fuel mixture etc.. having more air AVAILABLE through an aftermarket air cleaner wouldn't require a tune would it? That's like saying our stock breathers can't do ANY MORE at normal riding, it's at it's limit. Etc... and the Rushmore's already have a high flow system, are cammed up a bit, etc... It's not like you're SHOVING more air into the cylinder. Exhaust is one thing,, it scavenges from the cylinder, and if the exhaust is more free flowing than stock, (no cat, tuned head pipe, etc...) then it's going to flow more...and need a tuner. It just seems logical to me the motor won't suck more air than it needs,, no matter what the air cleaner is capable of.
