I have a 2012 HD Ultra Limited. I want to add a stage1 kit. I already have slip on Rhinehart pipes and ordered the air cleaner. I was going to do just a download and the aircleaner. I was talking to the service guy at the dealer and he said that it's better if I did the tuner, he said with the download, it's once and done, with the tuner I can obviously make adjustments as needed. I'm so freakin confused as to which way to go.
mruth551, I have a 2015 Road Glide with Vance and Hines Slip On's, Air Filter, and Harley Download. My bike runs perfect!!! Harley stated if I was not going to do more mods in the future this is a great set up, if I decide to do additional mods I can always dyno, add a tuner, etc...Try going with the download, if not satisfied get the dyno, tuner, etc...But it's going to cost you...Good luck!!!
Don't get the download. I had that on my 05, cooked a set of pipes. Use a tuner that will adjust your afr so you can cool the bike down a bit. The download leaves the afr "lean". Which means it's still hot as hell. Will you be removing the cat? Or leaving the header stock?
Mine is the same results as yours. Bike runs fine and just as well as last bike
with Fp3 . I want to keep my power train warranty in effect. First thing they note now is changes made to ecm and exhaust.
Extended warranty is the same . Mufflers are much cheaper than Engines and Transmissions.
