engine ping
Old Aug 6, 2017 | 01:05 PM
  #31
bigskyroadglide's Avatar
bigskyroadglide
Originally Posted by MDSledhead
2014 FLHTK (wethead)... after the engine is hot, I get quite a bit of engine ping on medium to hard acceleration.
I have over 20K on the bike... just had an ECM update that was supposed to help with this, but it's done this for quite some time (like since 10K miles). I always run 91+ octane.
This doesn't happen when I lug the engine, or when the engine is relatively cool (i.e. the first 15-20 minutes of operation). Hot engine 2500 - 4000 rpm.
Any ideas?
I would think several easy non expensive things could be done.
first off, i would change the plugs from stock to the vrod plugs. about $16 bucks and 15 minutes of time.
if that solved the problem, then nothing else.
next if i still got occassional ping, maybe seafoam or octane boost for a couple tanks of gas. $10 to $15 bucks
if still pinging, then i woukd consider xieds or vieds. $100 or around there.
then a tune, 400 to 600
ny .02
Old Aug 6, 2017 | 06:00 PM
  #32
tesnevo's Avatar
tesnevo
ny .02
Would the vrod plugs work as well on the 2014 110 motor (FLHTKSE) What makes these any better than the original plugs? Also is there a part number you know of off hand for them?
Old Aug 6, 2017 | 09:43 PM
  #33
bigskyroadglide
i ran vrod plugs in my 110 and now in my 120R.
they are 2 steps colder than stock plugs.
hd # is 10R12 vs stock plug of 6R12.
cheap fix if ping is occassionally present.
Old Aug 17, 2017 | 08:58 PM
  #34
MDSledhead's Avatar
MDSledhead
A little octane booster solved the ping. I literally can't make it ping even when I try. Seems like I can even lug on the engine a bit more (i.e. 2000 rpm).
Old Aug 18, 2017 | 08:24 AM
  #35
QNman's Avatar
QNman
How would colder plugs prevent ping? Not being a smartass, just genuinely curious.
Old Aug 20, 2017 | 06:57 AM
  #36
bigskyroadglide
Pre-ignition is the mixture igniting from something hot in the cylinder before the plug fires during the intake stroke. Usually occurs just after BDC. That can be a chunk of glowing carbon on the piston or half melted plug. Pre ignition you won't hear and usually detroys the piston or bends a rod.
Detonation is the pressure in the cylinder rising too fast during the burn and mixture spontaneously combusting before it's finished burning. That's what you hear as popcorn. Bad, but most motors will tolerate a little. Get enough det, the cylinder overheats, something glows, you get preignition and boom. Only takes a single pre-ignition event to kill a motor.
Det is almost always the precursor pre iginition. If it's an old motor running some intake and cc cleaner through it every once in a while can help reduce det threshold.
Even more important than the heat range is the mass of the tip. If the tip gets red hot and holds the heat, when the incoming charge hits it, pre-ignition can occur. Kind of like the glow plugs in a deisel. The standard plug has a large center electrode (~0.125 diameter) and is steel soit tends to retain heat, moving to a colder range does not 100% eliminate this but can reduce it enough so the problem does not occur.
thats why my 120R has 2 ranges colder, no ping, and able to run almost any gas, although i prefer 93 octane without ping.
hog120
Jul 8, 2014 12:54 AM
hockey8787
Sep 11, 2011 09:28 PM
DMas
Jun 1, 2009 01:28 PM
bobby5
Exhaust System Topics
Apr 9, 2007 06:15 PM
HDF Tech
Engine Mechanical Topics
Aug 2, 2005 06:13 PM
