== 2014 Limited Intercom System ==
Old Sep 17, 2017 | 08:38 PM
ACLazer's Avatar
ACLazer
Default == 2014 Limited Intercom System ==
I noticed when using the passenger/rider intercom system it lowers the Sirius radio volume, or Media volume, even when not talking into the microphone. Is there a way to use a PTT Button to use it, instead of using voice activation function to use it?
Thanks in advance!
Old Sep 17, 2017 | 08:44 PM
cycle7447's Avatar
cycle7447
Community Influencer
Yes - you can completely turn the vox off and when you do, you have to press the PTT switch to communicate.
Now, having said that, my bet is your vox is up pretty high and by it being that high, the wind is breaking vox and cutting the music off. Go to the vox setting and see where you are. My experience shows that maybe 4 bars from the left work pretty good. You can experiment with this to see what works best for you.
Old Sep 17, 2017 | 08:48 PM
ACLazer's Avatar
ACLazer
Thank you very much, I'll play with it more.
Old Sep 18, 2017 | 08:20 AM
striper.seeker's Avatar
striper.seeker
also be aware that if disable the VOX by going all the way to the left, when you press the PTT button for intercom, whatever you are saying will go out over the CB, if you have one and it's turned on.
Old Sep 18, 2017 | 05:14 PM
ACLazer's Avatar
ACLazer
Thank you, I will keep that in mind too.
mavantix
2014-2024 Touring Models
Dec 6, 2014 07:42 AM
sgl0226
Feb 23, 2014 02:12 PM
Scorpio49
Nov 4, 2012 09:53 PM
MikeDCop
Jun 12, 2010 08:44 PM
bob_kikkert
Apr 26, 2009 10:43 AM
