Brakes
Old Mar 6, 2018 | 03:07 PM
dyna07custom's Avatar
dyna07custom
Default Brakes
I have a 2014 FLHTK getting vibration in front brakes when applied above 60 MPH at 50 mph or less does not do it. Bike has 20,000 miles took it in to dealer because it was time for tires
Had new tires, replaced front wheel bearing, checked brakes and did flush and checked rotor run out also adjusted neck bearings and still there
Any Ideas
Old Mar 6, 2018 | 03:45 PM
Road Gliderman's Avatar
Road Gliderman
I would remove calipers clean pistons and clean and regrease pin that pads slide on. Make sure pistons are moving freely.
Old Mar 7, 2018 | 07:13 AM
dyna07custom
Thanks Road but I did that before I took it in all seemed fine
Old Mar 7, 2018 | 07:14 AM
undy's Avatar
undy
Check rotor run-out? Possibly one or both warped rotor(s).
Old Mar 7, 2018 | 07:34 AM
Jackie Paper's Avatar
Jackie Paper
Usually, vibration at speed like that is from rotors that have patches of too hard brake pad material stuck to them. Sand it off with 120 grit cloth or medium sandpaper. If that does not fix it, is there wear on rotors? Three sets of pads on a Harley pretty much wears them down to minimum thickness. Only takes about .030 on a side. Even with only .010 wear, if you ****** a hand full of brake often, they can get out of parallel. Then, it's worst then warped since it's like brake on and off. Cars and bikes skake like crazy at speed then when you brake.
Old Mar 7, 2018 | 05:05 PM
brokefootkenny's Avatar
brokefootkenny
in had same thing on my ultra, rotors were warped
Old Mar 7, 2018 | 07:37 PM
Two Lane Tramp's Avatar
Two Lane Tramp
Warped rotors!! Don't replace with Harley, Screaming Eagle is junk too. Find some quality aftermarket and enjoy.
Old Mar 8, 2018 | 01:41 PM
dyna07custom
Did you replace with OEM or something else?
Old Mar 8, 2018 | 07:30 PM
Two Lane Tramp
Performance Machine makes a great one. Kinda pricey but worth it
UltraClassic13
Mar 24, 2019 09:14 PM
brokefootkenny
Jul 24, 2017 08:30 PM
SeniorJeffe
Sep 20, 2016 06:28 AM
tidbit1
May 28, 2014 05:12 PM
keith t
Oct 2, 2011 08:09 PM
