New Suspension Time
After considering several options ,and reading people's reviews I gave Howard at Motorcycle Metal a call, I visited with him and ordered Ohlin #2 #2 shocks and his new 25mm adjustable cartridges for the harsh OEM front end.
They arrived about two weeks ago, been working a lot and on call lately so the install is hit and miss so far. Also have some new plugs , brake pads ,hyd clutch master cover , head bridges , and HD fork rebuild kits to install. Need to flush brake fluid while I'm at it.
FWIW, I just pulled my forks and used the fork rebuild kit you're going to use. For fork oil, I used a 50/50 mix of H-D Type E and Screaming' Eagle fork oil. I've never installed cartridges, so the only thing I have to compare to is the way the bike rode before I rebuilt them and all I can say is the way the bike rides now is as different as night and day. Along with my Ohlins rear shocks, the bike rides so much better than before. I wasn't expecting such a drastic improvement for the better.
The first pic is what I ordered from Howard , I asked him to include oil , and tools. He gave me the option to get oil myself ( Ohlin or KYB ) or he could include it.
So while this isn't the first time I've had these forks apart I'm far from an experienced suspension guy , I can call Howard whenever I'm not sure about something, not sure how many retailers offer that kind of support after the sale.
While it may be overkill I wanted a really good front end , didn't want to spend 1/2 or 3/4's as much to be disappointed then have to spend even more to be satisfied so thats how I came to this choice.
Being it's a sexy looking Street Glide means a little more work to get at the forks than a RG. I may have done more work than necessary but I wanted to break torque on the fork caps before I pulled them out of the tree , I believe the service manual tells you to , that means there's a few things in your way.
That switch cover has 2 stubborn connectors attached even though there are no switches installed , they need to be disconnected.
So I moved the fairing , rocked it forward out of the way , to clear the bars to be removed , but not before I pulled my R heated grip to move the power wire from 8:00 to 6:00 ,the throttle boss on Avons is screwed on from inside the grip so I adjusted that to a useful position , it's only been bugging 3 years now ! !
Now it's a clear shot , loosen the top pinch bolt 1st ( seen in the 1st pic just to the right and below the tape ) then just break torque on the cap and turn back lightly.
I can see one of mine had started to leak , this had a new kit 18K ago , on baggers the cow bell hides this from view. These were ready for a good cleaning , oil change , and seals either way.
Now put them in a vise with soft jaws ( I used a piece of bicycle tire ) to remove the fork cap . . . . . . wait hold up . . . I forgot to do this 1st on mine, break the torque on the damper bolts in the slider , as with the caps turn them back in lightly after you crack them so they don't leak oil.
Now with the fork in the vise put your socket in then wrap a towel around the top, keep a firm grip , keep your face and other favorite body parts out of the way and remove the cap. The towel will contain the cap from flying off as it's under spring pressure , USE CAUTION ! !
