Brake Pad Help
Old Sep 7, 2019 | 04:15 PM
Bodacious MC's Avatar
Bodacious MC
Default Brake Pad Help
I recently replaced all 3 pad sets on my 2014SGS. I was hoping for less brake dust then the OEM Brembos and purchased Sintered HH pads from D2Moto.
These things really whirl with noise. I took the rears off and lightly sanded them to see if that might help. No luck!
Is there anything else I can try or juck them and buy the HD Brembos and deal with the dusting?
Old Sep 7, 2019 | 08:03 PM
Harttoo's Avatar
Harttoo
Dp brake pads have no dust and make no noise.Slightly cheaper than brembo oem. https://www.ebay.com/itm/DP-Standard...333074418605?_
Old Sep 7, 2019 | 09:13 PM
chopper_man's Avatar
chopper_man
You need to chamfer the edges. Will remove about 90% of the buzz.
Old Sep 8, 2019 | 12:30 PM
Bodacious MC
Thanks chopper_man, i'll give that a try. Wonder why the manufacturer wouldn't do so during the build process?
BTW....."Buzz" is the perfect term for what I'm experiencing with my brake pads!
Old Sep 8, 2019 | 05:54 PM
2slow05's Avatar
2slow05
i looked at these brakes and on the website it shows the DP962 is standard but the SDP962 is optional, do you know the difference between the two i cant seem to find it on the website?
Old Sep 8, 2019 | 06:05 PM
Bodacious MC
Chamfer helped with 70% of the buzz. The fronts are now quieter than the single rear. May put on a couple of hundred before trying the DP962's or OEM Brembos for the rear.
I'm probably keyed into the noise because of my OCD now! Need to give the D2Moto's a few hundred to lap in.
Old Sep 8, 2019 | 06:22 PM
chopper_man
Did you get the center channels as well? I hit mine with a triangle file. Funny, the buzz drove me batty for the first few hundred til I tried the chamfer. Few hundred after and din't really hear it anymore unless I really listen. About 5k on them now and still buzz a bit. I think it's because the cross-drills on the rotors are not chamfered. They stop awesome tho once seated!
Old Sep 9, 2019 | 10:31 AM
Harttoo's Avatar
Harttoo
SDP are for off road and racing.Standard are all You need.
Old Sep 9, 2019 | 09:58 PM
2slow05's Avatar
2slow05
thanks i appreciate it
sullyj020
Aug 4, 2016 03:24 PM
toad6301
Jan 23, 2012 01:24 PM
myking
Wheels/Tires
Jan 31, 2010 04:54 PM
bucs012
May 12, 2008 08:07 AM
shearpinn
Jul 16, 2007 11:37 AM
