Squeek
Old Aug 5, 2020 | 11:20 PM
Drtumolo's Avatar
Drtumolo
Default Squeek
I am 1600 miles from home and I developed a squeak that Sounds like it might be the upper engine stabilizer. It only occurs when under light load or decelerating. This joint is the one in the front of the engine with hiem joints. The bike has 45000 miles on it and these joints look very dry. Has anyone ever had an issue with this mount causing a squeek.
Old Aug 6, 2020 | 01:42 PM
rcrankin's Avatar
rcrankin
I have not. 40K + miles on my 2014. Try dropping a little oil, or grease if you can get it in there, to see if it quiets down. If you still have squeak, it might be something else.
Good luck,
Rob
Old Aug 6, 2020 | 11:32 PM
rod5557's Avatar
rod5557
Default Squeak
Is the joint easily rotated.
mine was and replaced by Harley and is very snug.
UUNetBill
Milwaukee Eight (M8)
14
May 16, 2018 07:16 PM
OLD 96
Aug 6, 2014 09:04 AM
Terrabella
Jan 30, 2013 03:34 PM
lou1
Sep 23, 2011 02:05 PM
scaryonly
Jun 14, 2008 06:04 AM
