DIY Stage 4 install
First thing in order was to organize my new tool box. I used a sharpie to label what is in each drawer.
I set up a couple 6 ft tables to put the tins and stuff on, started taking off tank, seat, right floorboard, exhaust, etc
Heads and jugs off. Nasty tops for only 20K on the engine. popped off the c-clips and pushed out the wrist pins.
Had the jugs honed at a local machine shop. $42, wiped with clean engine oil, and slid the piston in and mounted it by sliding it down to get to the connecting rod and push the pin through. install remaining c-clip. The other one I used a ring compressor. I didn't have it available when i did the first one. Boy that makes it a lot easier.
Had to modify a 13/16 spark plug socket to transfer the ACR's. Worked like a charm. These are CNC Screamin eagle heads with heavy duty valve springs.
Had to cut down this allen to get to the back head bolt under the rear part of the frame, and the inboard lifter blocks.
Pulled the cam out. Borrowed a cam bearing puller/installer. will change the bearings them install the cams. 259E's came with the kit.
Assembly lube, the connecting rods, wrist pins, any metal to metal mechanical surface
Ring end gap
Ring order as well as direction
Rings go in dry, do not lube
The wrist pin "c-clips" are directional, sharp edge out and opening faces down
Pistons typically have a cam side indicator
Cylinders should just have a very light wipe of oil
ARP ultra-torque is fantastic stuff, make sure to use on clean, dry bolts and threads
Gasket mating surfaces, wipe with general purpose solvent (I like Wurth), let them dry and assemble
I received this tool from Amazon, it is a Hartland product, made in China. Notice how F'd one of the collets is? I believe the plate itself was part of the problem not allowing the collet to align up properly. Also, notice the smaller collet, how expanded the gaps are. The damaged one was the same way and instead of pushing in through the bearing rather easily, I had to force it through and it made metal, and even damaged the cage. It should have been pretty straight forward but it wasn't. Luckily, a buddy lent me his plate, from a better quality set. I used his plate and the Hartland collet, because his didn't have the 1 inch collet to begin with. It worked, and I hope I got all the shavings out. I used a good magnet to get out as much as I could. I am sending it back. There is a sticker on the box saying if Amazon won't return it, they will. Next is to put the bump stix in. Have to change the orings for the oil pump, there are 3.
After getting my heater hooked up and take the chill out of the garage, I bolted the cam/oil pump in, put a new tensioner shoe on, and set the timing chain. Need to lower it so I can torque the new bolts down. Will use red lock tite. The inside chain shoe was perfect, this one visible was worn so I got on amazon and ordered new ones, comes in sets of two. The oil pin and spring come out easily, but getting the insert took some tinkering. I ended up using snap ring pliers to grip the inside and pulled until I over came the suction of the pocket. Just now notice the kit doesn't have the cam cover gasket, sheesh. Back to Amazon.
