After market 4pt Docking Set
Old Feb 17, 2021 | 07:56 PM
Ridem-Rhody's Avatar
Ridem-Rhody
Default After market 4pt Docking Set
Anyone have recommendation for after market 4pt docking set. Is there really a difference that justifies the Harley Tax? I see them on eBay for less than half the price of OEM.
Old Feb 17, 2021 | 08:34 PM
Alex Anders's Avatar
Alex Anders
Unsure about the off brand part, but definitely keep an eye on eBay for a genuine HD set they can be had for about half of new. I know when I sold mine I had no luck and finally sold them for $55 on here in the classified section, I was surprised how little they brought.
Old Feb 17, 2021 | 08:46 PM
NODYNA's Avatar
NODYNA
Yes there is a difference in the chrome quality and fitment of the rubber/plastic parts. HDs are elliptical so you can rotate them for a secure fit fit. Some of the after markets are not correctly sized and there can be slack between the rack and the attachments. Like he said buy used H-D.
Old Feb 17, 2021 | 10:04 PM
Bent and Broken's Avatar
Bent and Broken
I was given an ebay bought docking system that I use on bike. There is a difference but not enough that I would go out and by the Harley model.
Old Feb 17, 2021 | 10:24 PM
bburky's Avatar
bburky
I bought harley docking hardware , and passenger back rest , it still fits like poop. It is so tight you can not twist the swivel locks without some sort of tool. I use a wooden hammer handle too install , and remove....so much for the magic hd perfect fit. On the flip side welds are all good , and I don't worry about women falling off because of inferior fabrication , that to me is worth the price of admission.
Old Feb 17, 2021 | 10:31 PM
vizcarmb's Avatar
vizcarmb
I have the ebay specials and they are just as good. No need to spend the extra money. Mine have never flaked or rusted.
Old Feb 18, 2021 | 07:01 AM
MCSarge's Avatar
MCSarge
The bushings on the HD mounts are not round they are more of an oval shape. If it is that difficult to install the latches then loosen off the mount bolts on the plastic bushings and rotate them a little until the latch goes on smoothly. I will leave then slightly loose and mount the rack/back rest etc.. and then go back and tighten the bolts. They are made that way so you can adjust them in case you get any rattles or in your case they are to tight.. Good luck on your project...
Old Feb 18, 2021 | 07:28 PM
craigffb's Avatar
craigffb
Try putting something like lithium spray lubricant on the black plastic part of the docking hardware. It will allow the swivel locks to work much smoother. It will change your life. Re-apply every time you wash the bike and you shouldn't have any more issues and you wont need a tool.
Old Feb 18, 2021 | 11:37 PM
bburky's Avatar
bburky
Thanks fellas , I shall take your advice , and apply it to my situation.
Old Feb 22, 2021 | 10:40 PM
josame's Avatar
josame
I sold my HD set to a guy that had the aftermarket set, he said he could not get rid of a rattle with the aftermarket set.
