What difference does the size of the muffler make? 3 vs 3.5 vs. 4 inch, etc...? My stock mufflers are 3 inches. Just want to make sure I understand before I pull the trigger on a new set of mufflers.
This is what I found.
"Exhaust backpressure can build up flow resistance and reduce pumping and creating more pressure on the piston if the pipe is too small. Similarly, a pipe thats too large will lower backpressure, and a lack of backpressure eventually decreases velocity."
I interpret that to mean my best best is to either keep the same diameter as stock or maybe go up 1/2 inch but not more than that. Stock seems to be 3 inches. Probably what I'll go with
This is what I found. "Exhaust backpressure can build up flow resistance and reduce pumping and creating more pressure on the piston if the pipe is too small. Similarly, a pipe thats too large will lower backpressure, and a lack of backpressure eventually decreases velocity."
I interpret that to mean my best best is to either keep the same diameter as stock or maybe go up 1/2 inch but not more than that. Stock seems to be 3 inches. Probably what I'll go with.
Didn't post that originally because I thought maybe I asked a question everyone else already knew the answer to except me. Sorry.
No worries. The reason I was interested is because I bought 4.5" slip-ons originally with no baffles and while it looks and sounded great, it killed my bottom-end torque. I wound up buying baffles and installing them to fix the problem.
Just wanted to see if you received an answer that would validate my experience...
