Heated grip issues
Old Mar 8, 2024 | 04:41 PM
BamBam17's Avatar
BamBam17
Stage II
Default Heated grip issues
I just installed a set of 12" meathooks on my 23 RG. For some reason even. I triple checked all of my wires and I still can't get the heat to come on. Any advice would be appreciated
Old Mar 8, 2024 | 05:52 PM
dawg's Avatar
dawg
Welcome to the forum. It must either be a connector or a wire or a fuse blown because of it. Electrical sucks to chase down sometimes, but if it worked before you did the install, you did something somewhere that caused it and now you’ll have to go back and trace wires, etc. till you find it.
Old Mar 8, 2024 | 06:20 PM
Ssitruc's Avatar
Ssitruc
After fuse is checked, I'd grab a meter and check for volts at every connector in the power circuit... I installed a set for a friend, and used one of the short extensions that came with the new set of HD grips. got it all done and before we put the fairing back on, tested the grips... nothing. The short extension, right out of the box, was bad. I rerouted the wires a little and was able to get it hooked up without the extension and all was well. Then I popped the pins out of the connectors on the extension, and one wire was crimped in the pin, but the insulation was still on the wire...
On that Road Glide, both your bike's connections (power and interconnect) for heated grips are under the gauges, do you have 12V there from your bike? Did you have to add any extensions?
Old Mar 9, 2024 | 07:01 AM
Magneto Man's Avatar
Magneto Man
Make sure the connector inside the right hand grip is seated correctly and locked in place. If it isn't making connection, nothing works.
jamala00
Screamin Eagle CVO Models
Apr 22, 2022 12:49 PM
AllenW
Sep 28, 2012 06:03 AM
rick-e-b
Sep 10, 2012 04:46 PM
mile high king
Feb 21, 2012 08:34 AM
Pine Tree
Oct 21, 2009 07:39 AM
